Hi, My HG 635 is currently on firmware v1.04ttb which seems to be pretty old.
How should I go about updating it, and is it worth the bother ? 🙂
Alan
As the firmware is showing as TTB (TalkTalk Business), are you a business customer , or are you residential, and is this a router you picked up yourself ?
Hi alancfrancis
You would need to contact TalkTalk Business to arrange the firmware update. This Community is for our residential service.
Thanks,
Is there a support community for TalkTalk Business ? Why does it need to be separate ?
Alan
Hi Alan,
Apologies, we wouldn't be able to update a business router incase the FW is a slightly different version to a residential router. There is no community for TT business and I can only suggest contacting them directly so that they have check if you have the latest firmware and update if needed.
