How to setup a new DDNS on Smart Hub?
ANSWERED
4 REPLIES 4
freestuff
Can you please help me setup a  DDNS host on the talk Talk Fibre Fast 5364 Smart Hub.
Thanks in advance
Solution
Hi @freestuff
Please see my attached guide on this subject, this does not cover the DNS proxy that works with the hub. That is the subject of another guide of mine, if I can help further just let me know.
freestuff
@KeithFrench Thank You so much....You made this so easy!
Hi @freestuff
No problem at all, glad to help. Out of interest do you have no-ip now working via the hub's dedicated Provider option, or did you use the dns proxy I mentioned?
freestuff
Hi @KeithFrench ,
Once again Thanks for your help!...
Sadly the dedicated settings in the router did not work for NO IP. I had to use the dns proxy you mentioned.
