Internet speed update not affected
19 REPLIES 19
Danillo
Hi, I recently updated my Internet speed from 39mbps to 61-73mbps (download). And I also bought the new router. So I received an email saying "We're currently processing your order for Faster Fibre Broadband. We will email you with any updates and you can also check your TalkTalk My Account for updates too." But I didn't got one, and also I have no information about the router that I bought with the Internet speed update.
I kept doing speed checks, and turning off the router for 30 mins and tuning back on didn't helped.
Can someone please help me?
Divsec
Hi @Danillo your post has been flagged for assistance, please update your community profile to include your phone line it is used to identify your account.
Danillo
Thank you, I have now updated my profile.
Hi Danillo
Apologies for the delay.
If your line was not in sync at the full 40mb before adding the fibre speed boost then the speed wont increase any further.
Divsec
Hi @OCE_Debbie @Danillo apologies for interference, does your reply mean that Danillo's order was cancelled and this info not passed or is there something else at play here?
D
Danillo
Hi @OCE_Debbie @Divsec.
So, I had a plan of 40mbps download speed, it was working fine, no problems.
But on Friday the 10th of January, I bought a new plan of 70mbps download speed, together with the hub.
The problem is that my Internet download speed still reaching 40mbps maximum, and I have no information about the hub.
Hi Danillo
I'm just sending you a Private Message to confirm some details so we can look into this further.
Hi Danillo,
Thanks for the PM
When did you request the fibre speed boost? How did you request it?
Danillo
Hi @OCE_Chris @OCE_Debbie  @Divsec
Sorry for the inconvenience, but did someone managed to look into my problem?I haven't received any news for some time.
Also, my hub/router just arrived, thank you.
I don`t understand, on my account it says. "Estimated speed of 40mb"
And on my order confirmation email it says "Estimated speed of 75mb".
Divsec
  • @Danillo thanks for the update on the router I think you will find the OCE team are awaiting response from you? This being the question yesterday.
Danillo
Hi @Divsec ,thaks for answering.
I don't know what happened, but I replied to @OCE_Chris  yesterday.
However, I made my order on Friday, 10th of January.
Using my phone I went to the TalkTalk mobile page, and there was a section called "TV, Broadband and Calls", I clicked on it and there was an option to buy the "Faster fibre boost" I bought it. I received the "order confirmation email" seconds after. But the "faster fibre boost" doesn't seem to be applied.
I have checked my "line connection speed" and apparently my line speed supports 40mb+.
Divsec
Hi @Danillo thanks for that goods news is with your router arriving you know your order worked! Maybe a glitch on the boost but @OCE_Chris will get to the bottom of that for you.
D
Danillo
Hi @Divsec
The router arrived! I just tested it, and it seems to be working perfectly. I will be waiting for assistance on the boost. Thank you.
Hi @Danillo
The boost has been applied, You speeds should increase in the next 24 hours.
Danillo
Alright, I did some testings and it hasn't changed yet. I will keep looking and waiting.
Thank you all for helping.
Hi Danillo,
Sync speed is now 76.6Mbps 🙂
Danillo
Hi @OCE_Chris
I did some speed checks this morning and my upload speed increased to 20mb as expected. But my download speed stayed at 40mb maximum.
I will do more testings this afternoon to see if it changed.
Thank you.
OK thanks. If you retest and there's no improvement can you switch your router off and leave it off for 30 minutes, then switch back on and retest
Danillo
I did the 30 minutes thing and it worked. Both up and down speed are running as expected. Thank you @OCE_Chris
Thank you all.
That's great news, thanks for letting us know 🙂
