New wifi hub keeps rebooting
23 REPLIES 23
robincm1
Just had my fibre wifi hub replaced because the old one kept rebooting in the middle of the night.
Unfortunately the new one seems to be doing just the same.
Also it is rebooting at only 30mbps while the old one sometimes got 40! (This was just after 3 engineering visits to sort out slow speed)
Any ideas?
OCE_Michelle
Hi robincm1,
I'm sorry to hear this and I'll take a look now. I've run a test on the line which hasn't detected a fault. Is the router rebooting at exactly the same time every night? Is the voice service ok with no noise on the line? Does it reboot at all during the day?
robincm1
Hi Michelle,
It usually reboots between about midnight and 5.00 am.
I've only had the new one a couple of days but the old one only very rarely rebooted during the day. It usually lasted longer between reboots when it connected at 30mbps down/10mbps up but at 32.4 and 35 and 40 it would only last about 24 hours.
Voice service is fine.
Cheers,
Robin
OCE_Michelle
Hi Robin,
Ok thanks for confirming this. Do you have any devices set on a timer to come on/off around the time that the router reboots? Once it has rebooted does it regain sync straight away?
How long has this replacement router been connected for?
robincm1
Hi Michelle,
Nothing on timers - all devices “sleeping” in middle of night! Don’t know how long it takes to sync as I don’t check till later in day.
New router has only been plugged in for 48 hours so probably still “settling in”, however I had expected it to stay online but perhaps with variable speed.
Cheers,
Robin
PS. Going away for long weekend tomorrow so won’t be able to monitor it daily until Monday.
OCE_Michelle
Hi robin,
Ok thanks for confirming this. Would it be possible to bump your thread (request an update) on Monday and we can check the connection stats again to see how the stability compares and also to see if DLM has made any changes to the sync speed now that this replacement router is connected?
robincm1
Will do.
OCE_Debbie
Hi Robin
I've checked the connection stats and the connection appears to have remained stable since 28/09 and sync speed is 30mb.
How have you found the connection since your last post?
robincm1
Hi Debbie,
Thanks for keeping an eye on my connection. I have just returned home after long weekend and, as you say, the connection seems to have been stable while I was away.
However the speed remains at 30mbps whereas I was getting 40mb after the last OpenReach engineer visit, so I am still well below the expected 38mb promised.
Robin
OCE_Debbie
Hi Robin
If the speed hasn't increased then we would need to arrange an engineer visit (Openreach)
Would you like to monitor the connection for a while longer to see if DLM makes any changes to the speed or would you prefer us to arrange an engineer visit?
robincm1
Thanks Debbie.
I think I will reboot manually tonight and see what happens.
I am away again next weekend till middle of Oct. so, if it’s ok with you, I will pursue the matter further then!
please keep the ticket open.
Cheers,
Robin
PS. Excuse my ignorance but I am not sure what DLM is.
OCE_Debbie
Hi Robin
No problem. It would be worth powering down the router for a full 30 minutes.
DLM monitors the line and adjusts the profile to get the best balance between stability and speed.
OCE_Chris
Hi Robin,
I've replied to your PM
robincm1
Hi Chris,
I have replied!
Robin
OCE_Chris
Hi Robin,
Thanks for the PM
Yes your speed should be higher than it is. Your master socket should have a test socket under the face plate - there's more information about master sockets here
Could you connect your router to you test socket and leave it there for at least 48 hours to give DLM chance to respond to any improvement
CHris
robincm1
Hi Chris,
Back from holiday!
Router has been plugged in to test socket all the time we were away (10 days). It rebooted at least once (10th Oct at 0530) if not more times (the TV box went off sometime around Wed 9th)
The speed is still down at 30mbps down & 10mbps up so there is definitely a problem somewhere.
I have had to plug router back in to normal master socket as the test socket way was blocking our phone extensions.
Kind regards,
Robin
OCE_Debbie
Hi Robin
Apologies for this.
If all testing has been completed with an alternative router at the test socket then the next step will be to arrange an Openreach engineer visit.
Please let us know if you would like us to arrange this?
robincm1
Hi a Debbie,
Yet another Openreach engineer!!! That’ll be the 4th engineer (2 Brightsparks & 2 Openreach!!!}
yes please.
Robin
OCE_Debbie
Hi Robin
What the did the last Openreach engineer advise?
robincm1
Hi Debbie,
When the last Openreach engineer left everything was working perfectly with a synch speed of 40mbps down and 10mbps up.
This lasted a few days before the speed started becoming erratic again and the router was replaced.
This has now been going on for months - TalkTalk initially informed me that I wasn't getting the expected speed in an email dated 9 July.
I am beginning to feel somewhat upset, to say the least so I am not at all keen to give up another half day of my time and accept that you might even charge me for the privilege!!!
Robin
