Upload speeds now struggling…
ukbeachbum
Whizz Kid
Message 36 of 36
Last week I had a fault with my broadband that caused my download speed to grind down to almost nothing. The fault was reported and it’s now back to normal, but my upload speeds are now about half of what they were. They’ve normally been around 8Mbs, but are now around 4Mbs.
I’ve restarted the router a number of times, even left it off over night. It’s been on for a couple of days now with no improvement. Something must have been changed when the engineer fixed my original fault. Can you check things on your end and get my upload speeds back to normal?
35 REPLIES 35
Message 21 of 36
wifi can be affected by things around you, other wifi signals etc, also some wifi channels can be better than others, so always good to try other channels.
Message 22 of 36
Yes, I can test it wired, but that’s not how I normally access it, and I was previously getting upload speeds of around 8Mbs over Wi-Fi.
Message 23 of 36
is it possible to test wired to the router as wifi will always be a little lower.
Message 24 of 36
This is tested over Wi-Fi about 20 feet from the router.
Just now.Just now.
Message 25 of 36
profile is currently set at 40/10, so this looks correct.
Upload speed estimate for the line is 7-8, can you run a speed test as Sam Knows Speedtest  and tell me what this reports.
Message 26 of 36
So how’re things looking this morning? My upload speeds still seem to be below what they were and what’s expected.
Any suggestions?
thanks
ian
Message 27 of 36
If the line remains error free, DLM will raise the profile in increments until it finds a balance between speed and stability.
If after 48hrs, and there is no improvement, providing the line tests are clear, we can take this to Openreach and request that DLM is changed to improve the speed.
Message 28 of 36
So I should leave the router on in the hopes that the speed will change once the line is proven to be stable, and I don’t want to turn it off to reset the connection, yes?
I have some work video calls coming up this week and I’m a little worried about the slower upload speeds affecting the quality of the call from my end.
Ian
Message 29 of 36
Good morning,
I've re-checked the connection stats now and there is no change as yet, however it can sometimes take up to 48-72hrs for DLM to make changes to the speed if the connection remains stable. We'll re-check the connection stats tomorrow.
Message 30 of 36
Of course. I'll leave it as is until I hear from you.
Message 31 of 36
Thank you. Would it be possible to keep the router connected to the test socket for now and I will check the connection stats again first thing in the morning to see if DLM has made any changes to the upload sync speed?
Message 32 of 36
My mistake. I found it and retested the line. Downloads still around 34, and Uploads just over 5Mbs, but I think they should be closer to 8.
Message 33 of 36
Thank you for confirming. I can see that upload speed hasn't increased. The 5C socket should have a test socket. I've included a Help Guide below,
Your guide to main phone sockets - TalkTalk Help & Support
Message 34 of 36
My master socket, an OpenReach 5C, does not have a test socket.
I’ve run multiple speed tests, through Wi-Fi and wired connections, all come back with a download speed around 34-35Mbs (which is where I would expect it), but my UPLOAD speeds might clip 5Mbs at the very beginning of the test, but quickly go down and very jerkily hover between 3Mbs and 4.5 Mbs, and this is the issue I’d like addressed.
Isn’t there a way you can see these results on your end?
Message 35 of 36
I'm sorry for the delay. I've run a test on the line now which hasn't detected a fault. Does your main socket have a test socket please? If it does then would it be possible to connect the router directly at the test socket please so we can re-check the connection stats again?
