Router Problems
6 REPLIES 6
I've been having trouble with my fibre broadband disconnecting for the last 3 months. I thought it was the connection dropping for a long time but I have had a sort of breakthrough. I have found the connection itself is fine, its as if the router stops passing the internet through after a device has been using it for a while. I can play ps4 fine on a wired connection then out of the blue I will have 2000ms latency making games online unplayable if I pull the ethernet cable from the back of the ps4 and pop it back in i can log back on fine. The same is true for our phone if they have been connected for a while they will drop to 0.5mb speeds and have huge latency but turning wifi off and back on will restore the connection. So far i have had new cables filters 3 new routers 3 engineer visits none of which have solved my issue. If anyone can help please
What make/model of router do you have & is the PS4's Ethernet adapter able to run at 1000M (1Gigabit), or is only 100M max?
Hi Keith
The router is a Sagemcom Fast5364. The ps4 has a 1 gigabit ethernet connection. But this problem is the same across all devices connected to the network I have a chromebook on wired connection and laptop on wireless and they are the same if your using them.
In that case, I'll ask the OCEs to investigate.
Hi Chris,
I'm sorry to hear this. I've run a test on the line which hasn't detected a fault and the connection looks stable. You mention in your first post that you have tested with 3 routers. Were they all the same make and model or different?
Hi Michelle
Its been 3 of the same Sagemcom routers. Ive added a network switch before the router and its now been 4 days without any problems so fingers crossed its sorted now thanks.
Hi Chris
That's great, thanks for letting us know 🙂
