Hello there !
Like others on this forum I am unable to use VPN services with my DSL-3782 router, while both my partner and I need to access employers' networks.
I have read that it is possible to receive an alternative router, would it apply in this situation?
Thanks in advance,
Martin Ramette
There is now new firmware that fixes the VPN issue. I have asked one of TalkTalk's OCEs to pick your thread up and upgrade it for you.
Hi Martin
Apologies for this.
There is new firmware for this router which should resolve the VPN issue.
Please can you factory reset your router using the pin hole reset for ten seconds, I can then connect to your router and check the firmware.
Hi Debbie,
Thanks for picking up this thread, and sorry for the lack of reactivity on my side, I was away for a little while.
I have done the factory reset as you asked pushing the button for 10s, and then the router rebooted (good sign, right?). Is there anything else you want/need me to do?
Martin
Hi Martin
I've checked and I can see that your router has the latest firmware version that should work ok with VPN.
Are you still experiencing this fault? If you are then I can send a replacement HG633 router for testing.
Hi Debbie,
Thanks a lot! It is indeed working at the moment, but it appears to be a bit unstable. For this reason it would be great to not close this thread just yet, I will keep you updated in the coming weeks.
Thanks again,
Martin
Hi Martin
If you do keep experiencing this issue then let us know and we will send a HG633 router.
