VPN not working after house move and new contract
ANSWERED
7 REPLIES 7
ajaxupgrades
After moving house a couple of weeks ago my VPN is now not working. New 18 month contract on the Unlimited, uncapped speeds (40/10) package using my own Fritz!box 3490. I need this to work from home and be on call.
Can this block on VPN use be lifted?
Start with the obvious, easy fixes. Save yourself embarrassment when you find out it's the microfilter that's knackered!
OCE_Chris
Hi ajaxupgrades,
We don't block VPN use, what actually happens when you try to connect to your VPN? Do you get any error message?
ajaxupgrades
Ah OK. I'll try my Aruba remote access point, Sonicwall software and web portal again this evening then report back the errors. I have an older Talktalk router I can plug in temporary to see if that allows a connection too.
Thanks for the speedy reply.
AjA
OCE_Chris
OK, please let us know how you get on 🙂
ajaxupgrades
No joy with the HG633.
  • Web portal - {URL}’s server IP address could not be found.
  • Aruba RAP - Will not connect back to main controller
  • Sonicwall client - Failed to connect to remote site
Can I get a test with the boost to see if that opens it up? That's the only difference I can think of as it was working before at the previous address, with both routers. The Fritz!Box has a bucket load more features so is my preferred choice but this has to happen or I'll be forced to exit the contract and switch ISP. 😞
I've had to drop back to Mobile Data for connection through to work in small bursts, not really suitable but more preferential to not being able to work!
AjA
OCE_Chris
Solution
Hi ajaxupgrades,
Thanks for the information
Can you switch your router off for at least 30 minutes, then switch back on a retest - please let us know how you get on
ajaxupgrades
@OCE_Chris I totally retract any blame I placed with Talktalk - the fault was at my end. I have a PiHole that has developed a fault and this was the issue. Time I reconfigure my whole network.
Thanks for everyone's assistance. VPN connection definitely not blocked by Talktalk.
AjA
OCE_Debbie
Hi ajaxupgrades
Thanks for keeping us updated. Please let us know if there is anything else that we can help with on the Community.
