Hi can someone help I have a cctv system which will only work on 2.4ghz broadband system
Will this still work if I was to upgrade to the fiber broadband?
All TT routers are dual band, so they have 2.4Ghz.
If you joined in the last few years you may well have a router that is compatible with ADSL and fibre.
What is the model number of your current router ?
Hi Samuel145,
Thanks for the update and please let us know if you need any assistance 🙂
