Bad wifi/switching providers
krychan8
Message 10 of 10
Hello I have a problem with my wifi hub, my wifi hub works perfectly through ethernet cables however the wifi is atrocious, both my smart tv's and my phones keep disconnecting from the wifi and I have to either reset the network settings on those devices or reset the wifi hub itself. I have tried separating the 2.4ghz and 5ghz lines however the problem still persists and i can't seem to find the fix. This takes me to the question whether anyone here would recommend going to BT as they offer full fibre 900 and talk talk doesn't yet.
9 REPLIES 9
Message 1 of 10
Hi krychan8
The Huawei WiFi Hub is on its way, please allow 24-48hrs for this to arrive.
Message 2 of 10
Yes we can do that
Message 3 of 10
Hi krychan8
I can see that you are using the Sagemcom WiFi Hub. Would you like me to send the Huawei WiFi Hub for testing to see how the connection compares?
Message 4 of 10
I have added the landline number
Message 5 of 10
Hi krychan8,
Can you please add your TalkTalk landline telephone number to your Community profile so that we can locate you on our systems
Message 6 of 10
Done
Message 7 of 10
Hi krychan8
  • Name
  • Telephone number
  • Alternative contact number
Message 8 of 10
I have been trying to get help with this issues for a while now, with no good results whatsoever so i might have to make the switch anyway
Message 9 of 10
Do you want help with your wifi issues, or are you going to switch anyway? If the latter then you can do this at any time subject to contractual commitments you might still have with TalkTalk.
