Can only run a speed test on my wireless devices.
missunify
Message 5 of 5
I'm trying to troubleshoot an issue and the first thing I would like to do is use talk talk's speed test on the website, but when choosing devices it only lists my phone and tablet, which are both wireless, and not my PC which is connected with an ethernet cable.
Is there any way to get around this other than just using a 3rd party speed test?
4 REPLIES 4
TheHornedOne
Insightful One
Message 1 of 5
Have you tried connecting the Desktop wirelessly, missunify?
~R.
paulshent
Message 2 of 5
Easy way.  From a Browser of your Choice, search for ookla.
Then run their test (no software install).  Same test that TT use, but via your browser.
Runs on systems using ethernet or wireless connection.
Message 3 of 5
@missunify Try this link
https://www.talktalk.co.uk/speedcheck/
Message 4 of 5
Are you accessing this via the website on your PC, via my account sign in?
If so it should just work, and you don't have to select a device, at least I'm never offered a choice.
