on 13-03-2023 04:18 PM - last edited on 13-03-2023 04:28 PM by ferguson
I've been having this issue since Friday.
My router drops out and can take 10 mins to re-connect.
I ran a TT fault check this morning and got an email to book an engineer.
When I click on the link and view the fault, the fault tracker is just a blank page with no options.
Fault ref: REP-12625183
Can someone help please? It's been dropping a few times every hour today with no way to get an update or progress this fault.
I've plugged my laptop into the router and logged in but there's no info on the router's dashboard. Just connected/disconnected status icons.
on 15-03-2023 11:53 AM
Hi nwilson992
Do you still need help with this?
on 14-03-2023 11:42 AM
I had this problem quite a while back. After a lot of backwards and forwards the solution for me was found in these very forums. My router required a firmware update. Once I had got that, I had no dropouts at all afterwards. It maybe worth you contacting Tech Support and asking for the update. See if that helps. Good luck.
on 14-03-2023 06:59 AM
Hi nwilson992
The line test is detecting a potential fault towards the property.
Can I just check, is the router currently connected at the test socket?
Have we recently sent you a router for testing?
on 13-03-2023 07:54 PM
Hi @nwilson992,
So just to clarify, when you log into the router, is it not displaying the normal info you would expect to see on its home dashboard, even when it is successfully connected to the internet ?
The support team here will be back tomorrow and will be able to help further.
