Constant DNS Errors and Intermittent Connection on Multiple Devices
jackyhutchinson
Message 2 of 2
I have been having issues with my broadband since last weekend with all devices keep showing up intermittent DNS issues. Sites like google will just come up saying site cannot be found and various dns probe and dns config errors.  After a 3-4 page refreshes the site will load.
It's doing this on all devices (laptop and a few different modern phones) so is resulting in instability and we're also getting various different speed test results from 1MBs to 42MBS
I have reset the router back to factory settings and still having the same issue.
The router is connected to the master socket and I've also tried connecting it via a different micro filter, directly into the internal socket in the master socket (after sliding out the plate) but continue having the same issue.
I've also tried testing different wifi channels but nothing is solving the problem.
The router device version is: DG8041W-2.T5 and I believe it is on the latest
Is anyone else having the same DNS issues and is there a way to resolve this? - think it's a router issue and not an issue with the line or sockets
1 REPLY 1
Message 1 of 2
Have you logged into the router and tried changing DNS settings to use other DNS servers to see if this keeps happening.
You could try Google - 8.8.8.8 &  8.8.4.4
