on 20-11-2021 08:18 AM
Hi is it possible to disable Upnp on my router please, i cant find any option in the router menus
on 22-11-2021 12:55 PM
OK, No Problem 🙂
on 22-11-2021 12:49 PM
Hi Karl this can now be closed, i bought a tp-link router and solved the issue
on 22-11-2021 09:24 AM
Hi stephen8485
I cant see the router online, can you power this off for 1 minute so I can check again.
on 21-11-2021 03:08 PM
You can only disable it on the Sagemcom if you have a minimum firmware version of V130.
on 20-11-2021 09:07 AM
Hi Thanks for your reply, the router i have is the sagemcom FAST 5364-3 i dont seem to have the option you mention in my router
on 20-11-2021 08:34 AM
Hi @stephen8485 you don't mention your router model? If it is DG8041
It's in the advanced and application menu.
