Faster fibre with 'speed' boost
1 REPLY 1
WaRRioR1976
Whizz Kid
DSL synchronization status:
Up
Connection status:
Showtime
Line Quality
Upstream line rate (kbit/s):
11992
Downstream line rate (kbit/s):
46646
Upstream noise safety coefficient (dB):
8.8
Downstream noise safety coefficient (dB):
16.7
Upstream interleave depth:
238
Downstream interleave depth:
3007
Line standard:
VDSL2
Upstream line attenuation (dB):
0.1
Downstream line attenuation (dB):
9.6
Upstream output power (dBm):
3.2
Downstream output power (dBm):
13.6
Channel type:
Interleaved
DSL up-time:
2 days 9 hours 52 minutes 3 seconds
Downstream line rate of 46646? That's a joke, right? I'm supposed to be getting minimum  guaranteed download speed of 53.6 mb.
It has been as high as 73 mb. Every time the router reboots itself,  the speed drops.
There's clearly a problem somewhere. Please can some body sort it out? I've down all the usual things, messing about with test sockets, changing micro filter etc.
I hope to see some improvement in download speed very soon.
Thanks, Ethan.
I'm a drummer in a very well known band and I'm also a world class racing driver.
OCE_Debbie
Hi WaRRioR1976
Apologies for this.
The line test is detecting a possible fault. Please can you connect the router at the test socket so I can run another line test in this set up?
