Faulty Router
Mark1988
Message 10 of 10
Hi, I believe my router (Talk Talk WiFi hub FAST5364-3.T8) if faulty, it is not connecting to the majority of my devices and has a very short range (maybe 4-5m if I’m lucky - it won’t reach from the living room to the kitchen or upstairs to the bedrooms). I have tried the online chat, but went round and round in circles for over an hour not getting anywhere (all they would talk about is me not having a TV account with talk talk, and wouldn’t accept the problem is the TV’s not connecting to the internet along with the majority of the other devices). Does anyone know how to get a replacement for a faulty router?
The range has been getting worse for a while, but today all of the devices apart from our phones will not connect, all of the sky Q boxes, all of the smart TV’s etc.
Thank you for any help. Mark.
9 REPLIES 9
Message 1 of 10
Hi Mark1988
I'm so glad to hear this, thanks for letting us know.
Debbie 🙂
Mark1988
Message 2 of 10
Hi, sorry for the delay in replying, the new router arrived okay and has been up and running for a couple of weeks now, and is working a lot better. Thank you very much.
Message 3 of 10
Hi Mark
No problem 🙂
Mark1988
Message 4 of 10
Okay thank you very much
Message 5 of 10
Hi Mark
Thank you.
Message 6 of 10
Hi Skynet, thank you for your message,  I connected my laptop which wasn’t working upstairs by wire last night and that worked okay, I’ll have a look into interference but it’s in the corner of the room with nothing new there, it was working fine but over time the signal has got weaker and weaker, and now doesn’t want to connect things at all. Hopefully the test router they are sending out will help, I’ll update you once I have received it. Thank you, Mark.
Mark1988
Message 7 of 10
Hi Debbie, I have updated my phone number in my account. Thank you
Message 8 of 10
Hi Mark1988
Please can you add your TalkTalk landline number to your Community Profile, I can then send you a replacement router for testing.
Skynet_TX
Message 9 of 10
Hi @Mark1988,
Do you have any devices connected 'wired', if so do these devices work well and get the speeds you expect.
This could be a router fault, but if it is only affecting wireless it could equally be Wi-Fi interference.
To troubleshoot Wi-Fi interference you could change the channels that your router broadcasts the Wi-Fi signal on, you can use free smartphone Apps like this to see what channels are being used within range of your smartphone, you can then change your router to use channels that are less congested.
If trying the above makes no difference then it may indicate an issue with the router, the staff here would be able to help with that.
Be aware that the Sagemcom router has a 'feature' called 'Wi-Fi Optimisation', this means it can change the Wi-Fi channel itself, overriding what you have set it to, it can randomly do this after minutes, hours or days !. So if you do find a channel that works well, but then things go bad again, check to see if the router has changed channel to something different to what you set it to. If you do experience this problem then just post back here to ask the staff to disable the 'Wi-Fi Optimisation' on your router, once that is done it will stay on whatever channel you set it to.
