Fibre 35 Speed Capped at 6.25 Mbps
DarrenJackson1
Whizz Kid
Message 6 of 6
Today a physical fault was fixed by Openreach and my line was reset. FTTC.
My router is synced at 12 Mbps, but a Speed Test reports 6.25 Mbps. No other devices are using bandwidth.
It's my line capped due to the previous fault?
5 REPLIES 5
Message 1 of 6
No Problem 🙂
Message 2 of 6
@Karl-TalkTalk yes, this is the speed before the fault. Thanks for checking. Long line!
Message 3 of 6
was this the speed you had before the fault.
Message 4 of 6
Morning @Skynet_TX
Thank you for your help, your suggestion worked. Speed restored to an incredible 12 Mbps.
Skynet_TX
Message 5 of 6
Hi @DarrenJackson1,
Try switching your router off for over 30 minutes, then when you switch it back on you will get a new session in the street cabinet, this can often get the throughput speed back up to something much closer to the sync speed after a fault has been fixed.
