Firmware update for HG635 router
Gibbons
Message 15 of 15
Hi just checking is the latest stability / firmware update available for this model and if so could I be updated please thank you 🙂
14 REPLIES 14
Message 1 of 15
Hi Gibbons,
Ok thanks for the update and please let us know if you need any assistance 🙂
Message 2 of 15
Hi Debbie the connection seems okayish just monitoring it.
There doesn't seem to be any noticeable problems as of yet but if their is I'll be back in the future 🙂 Thanks.
Message 3 of 15
Hi Gibbons
Please let us know how the connection compares with this router.
Message 4 of 15
I have a DSL3782 as well as a HG633 I just took the other model out of box/plastic it's as good as new thank you for the offer Debbie but I'll think I will leave it I will switch routers to see if it makes any difference.
Message 5 of 15
Message 6 of 15
Hi Gibbons
I can send either a HG633 or DSL3782 router, which would you prefer to test with?
Message 7 of 15
Hi Debbie no problem is it the same router? lol
I've received a replacement router before in the past for testing.
Thank you for offering anyway appreciated.
Message 8 of 15
Hi Gibbons
Apologies for the delay.
The line tests haven't detected any faults on the line. I can send a replacement router for testing, would you like me to arrange this?
Message 9 of 15
My devices connected to the router get regularly discounted & refuse to connect for periods of time my broadband speed also seems to have been reduced this past few weeks.
I thought I'd give it sometime to straighten itself out to repair itself.
my connection for sure is not as fast or reliable as it once was.
I am unaware of what the problem is I thought the router might perhaps need a firmware update.
Message 10 of 15
Hi Gibbons
No problem. Are you experiencing any issues with the connection/router?
Message 11 of 15
Thank you for help Debbie 🙂
Message 12 of 15
Hi Gibbons
Thanks. The HG633 router has the latest firmware version v2.00t.
Message 13 of 15
Hello Debbie yes I currently am using the HG633 router & it's plugged in and switched on.
Message 14 of 15
Hi Gibbons
Are you currently using the HG633 router?
