Frequent disconnects - getting worse
harrybarman
Message 71 of 71
Just back from 2 weeks away and my broadband is suffering from very frequent disconnects (every 5 minutes or so). It's extremely hard to work using the connection.
It started to degrade after OpenReach did some work on the telephone pole servicing my house. The landline on a different pair was out of action (and fixed). I am getting dialtone on the talktalk line. Before going away I had periods where I had frequent disconnects but nothing like this.
Can you help?
Harry
70 REPLIES 70
Message 21 of 71
BTW... I did try using the test socket with filter and the new faceplate which has a built in filter.
I'm in for the rest of today and Friday. Next week is flexible.
Harry
Message 22 of 71
Hi - the engineer came first thing and changed the master socket. Although the line connected before he left we've now completely lost connectivity. No light on the router, no dialtone on the phone.
The connection was lost around 9.30 when the engineer said a line test would take place. But as it's now 11am I'm thinking something must be wrong again.
For now I'm using my mobile phone to connect but the signal is terrible.
Assuming this isn't something that can be addressed remotely please can we get a another visit from the field circus.
Harry
Message 23 of 71
Hi harrybarman
I've arranged the engineer visit for 04/10 AM (8am - 1pm)
Message 24 of 71
Thanks Debbie!
Message 25 of 71
Hi Harry
The line tests are clear so the next step will be an Openreach engineer visit to the property to investigate further.
Message 26 of 71
Hi Debbie. We had the openreach engineer over on Saturday and he renewed more cable jointing in the street. Sadly I'm still getting disconnects. We will need another call booked in. Today, Wednesday and Friday this week are good. One place that hasn't been looked at so far is at the top of the telephone pole - but for this openreach need a cherry picker.
Harry
Message 27 of 71
Hi Harry
It appears that the fault should now be resolved.
How's the connection been over the last 24hrs?
Message 28 of 71
Message 29 of 71
Great - thanks for all your help with this Chris. I'll keep you posted.
Harry
Message 30 of 71
Line test has failed with an error code that requires us to raised this as a non-appointed issue. Openreach will investigate over the next 72 hours and may contact you directly if they need to access your home
if you don't hear anything by Tuesday please bump the thread and we'll check for updates
Message 31 of 71
I'll book the engineer now and get back to you with the details
Message 32 of 71
Logs below... you can see why this is getting very tiresome...
29.09.2023 11:15:35InfoSYS
TR-069 connectivity to (acs.talktalk.co.uk) has been closed
29.09.2023 11:15:31InfoDHCPC
The WAN DHCP client IP address 92.13.162.61
29.09.2023 11:15:23InfoSYS
Modem login was successful
29.09.2023 11:14:26InfoDHCPC
WAN DHCP client (1) started
29.09.2023 11:14:23InfoXDSL
VDSL connectivity is up port 1
29.09.2023 11:14:00WarningDHCPC
WAN DHCP client (1) stopped
29.09.2023 11:13:59InfoXDSL
VDSL connectivity is down port 1
29.09.2023 11:03:48ErrorDNS
DNS name resolution failure (checkin.tower-research.com)
29.09.2023 11:03:35InfoSYS
29.09.2023 11:03:32InfoDHCPC
29.09.2023 11:03:00InfoDHCPC
29.09.2023 11:02:57InfoXDSL
29.09.2023 11:02:32WarningDHCPC
29.09.2023 11:02:31InfoXDSL
29.09.2023 11:02:14ErrorDNS
DNS name resolution failure (92.13.188.141.gb.inc6.355290479.pixel.archive.ph)
Message 33 of 71
Yes - off, amber, amber flashing, amber/white alternating, white. Wait for between 3 and 10 minutes and then the cycle repeats.
Message 34 of 71
Did you notice if the light changed on the router when the connection dropped?
Message 35 of 71
Yes - sadly the problem is not resolved. I've been getting frequent disconnects this morning. Please can you arrange another engineer visit? Monday/Weds/Fri next week look good.
Harry
Message 36 of 71
OK Harry, please let us know how you get on
Message 37 of 71
Unfortunately I don't think the problem has been resolved. Just had 2 disconnects within a 10 min period. I'll update again later, but I think another engineer visit may be required.
Harry
Anonymous User
Message 38 of 71
Good morning,
Thanks for the update and we'll check back in with you in a few days just to ensure that the connection has remained stable if that's ok?
Message 39 of 71
Yes - that must have been it. 4h33m uptime which is a record given previous performance!
Message 40 of 71
Hi Harry,
Sounds like it could have been your engineer. It may be that the engineer is still working on it and may still contact you
Anonymous User
