Hardwiring issues from eero6
Mark551
Message 5 of 5
Just had my new eero6 router installed and now my devices in the garden connected via hardwiring don’t work. They worked perfectly before. Do I need to do anything to liven up the Ethernet port or carry out any configuration?
Any suggestions much appreciated.
4 REPLIES 4
Message 1 of 5
Hi Mark,
Do you have any devices that connect wired to the eero ok? Which devices won't connect?
Mark551
Message 2 of 5
Thank you for your replies.
I have tried to connect the device both via the switch and direct, both without success.
Message 3 of 5
Hi Mark,
Thanks for your help @KeithFrench
How are you getting on?
Message 4 of 5
Is this going via your own data switch? In the Eero app can you see any of those devices connected? What happens if you just try one device, with a new Ethernet cable connected directly to the Eero?
