Inconsistent wi-fi
delypo
Message 127 of 127
I have had  the Huawei HG633 router for nearly 10 years. Whilst the fibre broaband speed coming into the house meets what Talk Talk guarantee, I experience WiFi inconsistency most days, with devices dropping connection, which requires frequent reboots of the old router to re-establish the WiFi connection.
I can see you offer a superior router to your new customers. As a customer of almost 18 years standing, could my old router please be upgraded? Thank you.
DP
126 REPLIES 126
delypo
Message 21 of 127
@Debbie-TalkTalk yes, I'm happy to accept and try another F266 Booster.
Message 22 of 127
Hi @delypo
I think we should send another WIFI extender, as this may have been an issue with the router firmware not updating before connecting the extender.
Are you happy for me to arrange this?
Message 23 of 127
Hi @delypo
I have sent my theories to @Debbie-TalkTalk. I have asked Debbie to consider something, so please watch this space....
Message 24 of 127
Thanks @delypo this possibly confirms what I think might be happening, but I need to look at another case or two, before putting mu guesses to @Debbie-TalkTalk
Message 25 of 127
Hi @delypo
Perfect thank you. I will let you know as soon as the team/devices manager comes back to me.
delypo
Message 26 of 127
@Debbie-TalkTalk for further information, the router is on its own shelf away from any other electrical devices. The F266 is about a meter away from it.
delypo
Message 27 of 127
Morning @Debbie-TalkTalk
The F266 is in the same room as the router and no, it is merely plugged into a mains socket with nothing in the ethernet ports. I don't understand 'is the customer attempting to use a wired backhaul from WFH <>F266' so I assume I'm not!
Message 28 of 127
Morning @delypo
Sorry just a couple more questions from the Devices Manager.
Q1 - Where is the router located and where is the F266 located? Are they in the same room or different rooms?
Q2 - Does the F266 have anything in the ethernet port? Is the customer attempting to use a wired backhaul from WFH <> F266?
delypo
Message 29 of 127
@KeithFrench
I've just remembered I took a 3 minute video of the F266 booster as it moved into its failed state. I would post it here, but the file size is too large. This was taken on 25th July so definitely before you arranged for my Fast 5464 firmware to be upgraded. In case it helps here's a description of the light sequence with timings:-
00:00-00:23 Flashing blue and green
00:23-01:20. Flashing Orange
01:20-02:06. Flashing Orange but light speed increased
02:06-02:08 Solid Orange
02:08-02:48 Returns to  Flashing Orange at the faster speed
02:48-02:58 Solid Orange
02:58 Solid Blue
delypo
Message 30 of 127
@KeithFrench I believe I witnessed that light sequence on first set up of the 266 and again after I tried a factory reset of the booster, so probably prior to the FW upgrade of the Fast 5464.
Message 31 of 127
Thanks @delypo, can you remember which side of upgrading the first router to V202?
delypo
Message 32 of 127
@KeithFrench I definitely recall seeing the lights flashing blue and green and referring to the set-up guide to establish that it was probably doing a software update. I don't recall it taking forever before this particular light sequence changed.
Message 33 of 127
Hi @delypo and @Debbie-TalkTalk FYI.
I have just started working on another similar case with the V2 F266 being unstable like yours. This is probably nothing, but can you remember the light flashing blue and green indicating it's updating software) at all? If so did it take forever to complete? I am just wondering if this is common & perhaps the 266 has been powered off during a firmware update.
Message 34 of 127
Thanks @delypo
I've passed on your reply to our Devices Manager now and I will post back as soon as they come back to me.
delypo
Message 35 of 127
Good morning @Debbie-TalkTalk @KeithFrench
Yes, we were supplied with a Fast 5464 router in May this year to assist in sorting our initial issues. keith was assisting and recommended a WiFi booster would help issues we were having with low speeds in certain rooms. Booster F266 V2  FW version 1046.9 was supplied at end of July. It was set up exactly as instructed in the accompanying set-up guide but constantly dropped signal every couple of minutes. Our Fast 5464 router firmware was upgraded to V202 to see if that would help, but no luck. So a replacement router Fast 5364 was sent at the start of this month and the upgraded FW V202 was requested prior to attempting to link the F266. Experienced exactly the same issue with Booster being unable to hold a signal.
Message 36 of 127
Message 37 of 127
Hi @Debbie-TalkTalk
It was originally a F5464, which subsequently got replaced by the F5364 (no DV, so no problem) running V202 firmware. The V2 F266 is running V1046.9.
I assume that @delypo connected them via WPS in accordance with the setup instructions, but I guess that we will need the customer's confirmation on that.
Message 38 of 127
Hi @delypo and @KeithFrench
Our Devices Team have asked if you could confirm what devices the customer was sent and what the setup process they followed was?
Message 39 of 127
Morning @delypo and @KeithFrench
Apologies for the delay. I've chased the team again for an update.
Message 40 of 127
Hi @delypo
I have just asked @Debbie-TalkTalk to see if there is any update from their Devices team for you.
