Intermittent connection since full fiber upgrade
gabzby28
Message 19 of 19
Hi guys! Since they upgrade my broadband last 20th of August for full fiber. The connection always on and off like every hour. I tried to reset it but internet connection still on and off and I am feed up with it. It did not happen with old one. Could it be the problem with router? Thanks
18 REPLIES 18
Message 1 of 19
Hi gabzy28,
Has there been any improvement at all with the new router as the authentication logs are showing much fewer disconnections over the last couple of days?
gabzby28
Message 2 of 19
The lights on the wall is always green although it would be 3 or 4 greens sometimes, does not turn orange even if the router is orange or changing lights
Message 3 of 19
Hi gabzby28
I've just done a quick check on the line which has come back with - Our latest check showed that line is functioning as it should
Can I just confirm, are any of the lights changing on the ONT box (on the wall) when the connection drops?
gabzby28
Message 4 of 19
Yes, the white light randomly blink and turn to orange, and then sometimes stuck to orange then blink again with white lock. So far, its not frequent as last week. I don’t know what the root cause, with old fiber, did not encounter issue with connection.
Message 5 of 19
Hi gabzby28
Can I just check, does the white light go off on the router?
gabzby28
Message 6 of 19
I’ve got received the new router and replaced the old one. However, same problem exists, still on and off internet connection. I don’t know if the fault is the fiber itself since upgrade. Please help me fix this one.
Message 7 of 19
I've requested a router for you.
gabzby28
Message 8 of 19
Yes please, send a new router so I can really test if the root cause is the router itself of connection problem. Thank you
Message 9 of 19
I'm sorry to hear this. Would you like us to send a replacement router for testing purposes to rule this out?
gabzby28
Message 10 of 19
Hello, still intermittent connection over the evening,  on and off connection. Im so frustrated now. Help me
Message 11 of 19
I've updated the router firmware, see if this is better over the course of this evening.
gabzby28
Message 12 of 19
Im using wifi hub, fast 5464
Message 13 of 19
Thank you. Can I just confirm, are you using a eero or the Wifi Hub router please?
gabzby28
Message 14 of 19
Updated details
Message 15 of 19
  • Name
  • Telephone number or Account number
  • Alternative contact number
gabzby28
Message 16 of 19
I have spoken with your experts already and they said it was not updated witg configuration so he did but seems like still an intermittent connection
gabzby28
Message 17 of 19
The fiber lighst are solid with green lights. Its the router that has on and off orange light flashing
Message 18 of 19
I'm sorry to hear this. Do any of the lights change on the ONT or the router when this happens please?
