Internet Down, White light on. Works again on restart.
mdc0111
Message 12 of 12
My internet has been on and off since friday - so into day 4.
Line check says its ok.
White light is on the router
Internet is restored if I turn it off/on.
Internet stays up between 30mins and 2 hours before it's down again.
Looks like a router problem.
11 REPLIES 11
Message 1 of 12
Hi @mdc0111
This is the latest update on this fault.
Update 8:40PM  December 17th 2024 - Our team are in the process of applying a solution to all impacted Wi-Fi Hubs and aim to resolve this by tomorrow morning.
Message 2 of 12
Service Status Dashboard is keeping people informed to some extent, @mdc0111. The highlighted Broadband button is the place to look:
https://community.talktalk.co.uk/t5/Service-Status-Dashboard/bd-p/service
Message 3 of 12
What is the latest on a fix ?  I still have this problem
Message 4 of 12
Hi @mdc0111
Ok, thank you for trying.
Our Network Team/engineers are working hard to get this fault resolved ASAP.
Message 5 of 12
Karl - I cannot get to that page - I get as far as the Wifi-Hub and it kicks me back to the login screen.
David.
Message 6 of 12
Can you change the DNS Settings in your router to use Google DNS, and test this over the course of the day to see if this resolves the connectivity issue where the router light remains white.
Please report back if this does help as this will aid our investigation.
Change your router DNS settings to use Google DNS.
  • Open your web browser, type http://192.168.1.1 into the address bar and press Enter
  • Enter the username admin (in lowercase) and password (you'll find this on the removable settings card on the back of the Hub, and select OK
  • Select See internet settings
  • Select Manage advanced settings
  • Select TalkTalk WiFi Hub
  • Select DNS Tab
  • Make sure ON is enabled
  • Add Primary and Secondary DNS Servers ( Primary = 8.8.8.8  Secondary = 8.8.4.4 )
  • Select Apply
Please note ;  If you currently use any Homesafe services such as Homework Time etc.  This will not work whilst you have the DNS set to Google.
Gliwmaeden2
Message 7 of 12
@Durhamwasp, @mdc0111, @melissamurrayx, @Adetrick @Damien82
Staff have been looking into this since coming back on here before dawn! It will take some time to get feedback since they have escalated the issue and it's so widespread.
Please only follow up on your own thread. Staff will reply to the original poster.
Durhamwasp
Message 8 of 12
Exactly the same for 2 weeks now, even with a new router sent out
melissamurrayx
Message 9 of 12
So many people having the same issue yet very little is being done to resolve it by talk talk i’ve been having the same issue for around 2 weeks new router that was sent is just doing the same thing
Adetrick
Message 10 of 12
Same problem here, you're not alone!
Damien82
Message 11 of 12
Exactly the same issue since Friday
Damien
