Internet connection disconnecting and intermittent crackling on phone
johnny95
Whizz Kid
Message 123 of 123
My internet connection has been disconnecting for serval months. Recently it has got worse. I also have intermittent crackling on the phone. I was using the black Huawei hub and then the Sagemcom WiFi hub 2.
However they both were rebooting automatically. So I then tried a different setup with a router and modem. I used the BT Huawei Echolife HG612 provided by Talktalk a while ago, and a Eero Pro 6 router. The DSL on the modem did the same and kept dropping. I'm now using a Draytek Vigor 166 modem with the Eero Pro 6. Unfortunately this modem also dropped DSL. So it's fair to say it's the internet connection where the problem is.
I have now connected my modem to the test socket on the master socket. It's been connected for just over a week. As far as I know it hasn't dropped so far. I'm thinking it may be the faceplate on the socket that could be the problem? However I'm not 100% sure. It could be a line or exchange issue? I had an issue with the exchange over 10 years ago, where the filters needed replacing. Maybe it's the same issue, I'm not sure.
As there has been so many disconnections my speed has dropped from 58Mbps to 44Mbps. I'm guessing the DLM has slowed it down?
Please can you help,
Cheers,
John
122 REPLIES 122
Message 21 of 123
Thanks, Michelle.
Can you tell me what my Sync Speed is now?
Thanks,
John.
Message 22 of 123
Morning John,
Thanks for the update and I'm glad to hear this. If the fault was found on Openreach maintained equipment then no charges will apply. We'll check back in with you on Monday to see how your connection/speed has been.
Message 23 of 123
Hi Chris,
Just to let you know the OpenReach engineers have been. They found the loop fault was at the telegraph pole outside. Water had caused some damage. I’ve attached a photo of the faulty parts.
My download speed is 51Mbps now. The engineer quoted 60Mbps, so I guess speed will increase in the next few weeks, as the connection stays stable. As the problem was outside, I guess there aren’t any charges?
Cheers,
John.
Message 25 of 123
Thanks. I will do.
Message 26 of 123
I've booked the appointment for - September 11 2024, PM - please let us know how you get on.
Message 27 of 123
Cheers, Chris.
Message 28 of 123
Thanks. I'll book the engineer and get back to you with the details
Message 29 of 123
Ok, Chris I’ve added my mobile.
Message 30 of 123
Could you add your mobile number to your community profile and let us know when you've done this. We will then book the engineer (yes it will be an Openreach engineer)
Message 31 of 123
Ok cheers. Would this be an OpenReach engineer to look at the socket and line etc? I'd like an engineer visit then please.
I accept potential chargers
PM 1pm to 6pm would be great
Not sure I should put up my number here?
Message 32 of 123
The type of engineer we book depends on the line test results. If the line test passes then it's always an appointed visit to the home (if it fails then it depends on  the type of fault found). If you'd like us to go ahead with the engineer visit Can you confirm:
  • Confirm your mobile number
Message 33 of 123
That would be great, however do you think it could still be an issue at the cabinet? Would it be possible for OpenReach to recheck if there is an issue there first?
I say this because I had an similar problem around 12 years ago, where an engineer went to the cabinet to fix the issue, but it was only a temporary fix and a second visit was needed which did fix it. The issues were the same as this. So this situation is ringing a bell.
Thanks,
John.
Message 34 of 123
OK  thanks. The speed is just a little below the guaranteed minimum so we can arrange an engineer visit to see if there's anything further that can be done to improve the speed, would you like us to do this?
Message 35 of 123
Hi Chris,
It’s been fine. Still getting 45Mbps download.
Message 36 of 123
Hi johnny95,
How has it been over the weekend?
Message 37 of 123
I’ve tested multiple routers and had the same issue so I'm sure it's not that. I’m currently using a new modem and a new Eero Pro 6 router. As the fault was at the cabinet recently it seems like it's the same issue.
Message 38 of 123
Thank you. It's still showing the loop fault. Have we recently tested with a different router too?
Message 39 of 123
Ok back in the test socket.
Message 40 of 123
Ok I'll do it now. I'll let you know in the next 5 mins when it's done.
