Internet drop
leecarey
Message 10 of 10
Hi all, my internet goes around the same time every day between 15.30 and 16.00 not sure why, using hg635 router  can take a while to come back on
9 REPLIES 9
Message 1 of 10
Hi Lee
Would you like me to send a replacement router for testing?
Message 2 of 10
All devices drop,
Cheers lee
Message 3 of 10
Hi leecarey
Does WIFI drop on all devices?
Would you like to try a replacement router?
Message 4 of 10
Different problem from last year
Cheers
Message 5 of 10
Hi all narrowed it down its its  the WiFi that drops out randomly done it loads today
Cheers
Message 6 of 10
Hi Lee,
Is everything still ok ?
Message 7 of 10
Hi ady
I have got 2 other routers, but they were unreliable , so I went back to my old hg635, seems to be ok at the moment
Cheers lee
Ady-TalkTalk
Message 8 of 10
Hi leecarey, I've run a couple of line tests and they're both clear and show your connection is good. Is your router connected to a power socket or a multi gang with other devices? Have you got another router you can test with?
Ady
Divsec
Message 9 of 10
Hi @leecarey your post has been flagged for assistance and you should hear during tomorrow. Is this a continuation of your problem from last year?
