Low Fibre Speeds
chris12341
Message 90 of 90
Hi!
I have recently started having trouble with my broadband speeds. My guaranteed download speed is 33mbps. Until recently I have been receiving anything between 40-42mbps. However, I have been having trouble for the last few days. Speed tests this evening have shown widely fluctuating results. For example, a speed test taken at 8.32pm showed a download speed of 0.8mbps, but one taken at 8.40pm showed a download speed of 41.6mbps! At 8.48 it was back down to 15.1mbps.  The last test (at 8.58pm) showed 27.7mbps.
Can anyone help please? I have tried turning off the router, but it made no difference. I did wonder if the age of the router made any difference. I have had the one I am currently using for some time. I believe that it is an old one - a Huawei HG633.
Any assistance anyone can give will be much appreciated. Many thanks.
89 REPLIES 89
chris12341
Message 81 of 90
Hi Debbie,
I have carried out further speed tests over the weekend, using both the old and new router.
The Huawei HG633 seems to be working fine again, and shows higher speeds (both download and upload) than the new router. There is a difference in download speed of 2-3mbps (between 41-42 with the Huawei compared to 38-39 with the new router). This is confirmed by checking the speed history in the 'My Account' section, which shows a slight reduction in speed since the new router was installed on Friday.
I have completed more speed tests this evening, using only the new router, which show a download speed of 39mbps. This is still higher than the speed guaranteed by TalkTalk.
I will leave the new router connected, and continue to monitor the speed over the next few days.
Message 82 of 90
Morning Chris
Please let me know if the speed is still low.
chris12341
Message 83 of 90
Hi Debbie,
The router arrived today.
For comparison, I have run speed tests on both routers.
The old router (Huawei HG633) showed a download speed of 41.5mbps, and an upload speed of 4.7
The new router is not performing quite as well, although it is still meeting the guaranteed download speed (33mbps). The new router shows 38.6 download and 3.9 upload.
I will continue to monitor (using the new router), and will update you on Monday evening (hopefully!).
Message 84 of 90
HI @chris12341
Have you received the delivery notification for the new router?
Message 85 of 90
chris12341
Message 86 of 90
Hi Debbie,
Thanks for sending the replacement router.
Tests this evening show a download speed of just over 41mbps, so hopefully the problem has resolved itself.
I will update you once I have tested the connection with the new router.
Message 87 of 90
Hi @chris12341
chris12341
Message 88 of 90
Hi Michelle,
Thanks for your quick reply.
I have carried out more speed tests this evening, and the problem seems to have sorted itself. Download speeds this evening were measuring between 40 and 41mbps.
If possible, could you please send a replacement router anyway.
Message 89 of 90
Hi Chris,
I'm sorry to hear this. I've run a test on the line now which hasn't detected a fault. The HG633 is one of our older routers. Would you like us to send a replacement router for testing purposes to rule this out and see how the connection compares?
