on 31-10-2024 12:30 PM
I have a new modem a Sagemcom F@st 4370, coming from a Huawei MT992 with a Gfast connection. Tested the internet downspeed, where in the past I was getting 280mbps i'm now getting 190mbps.
Do I have to wait until the DLM adjusts to the new Modem?
2 hours ago
Could you try powering down the router for a full 30 minutes and then retest the speeds again please as this can often increase the throughput speeds.
on 20-11-2024 10:48 AM
Charges would not apply then.
on 20-11-2024 10:47 AM
Yes the issue was in the cabinet.
on 20-11-2024 10:46 AM
If the fault was located on Openreach maintained equipment then no charges should apply.
on 20-11-2024 10:43 AM
Just to confirm I won't be charged £75 as it was an external fault?
on 20-11-2024 09:49 AM
Good morning,
I'm glad to hear this and thanks for confirming.
on 20-11-2024 09:41 AM
Yes the issue has now been resolved.
on 20-11-2024 07:26 AM
I'm really sorry for the delay in getting back to you. Has the engineer managed to resolve this for you or do you still need our assistance?
on 18-11-2024 11:04 PM
Re-escalating this for you, @coinup.
on 18-11-2024 10:32 PM
Just checking things, and for some reason my internet speed has suddenly in the space of a couple of hours been reduced to 70mbps or so down and 20mbps up speed. I have arranged hastily for an engineer visit hoping for the issue to be fixed or has someone made an error somewhere??? at talktalk?? were my normal speeds for the last several years have been in the 280mbps down speed range.
on 01-11-2024 12:34 PM
No Problem 🙂
on 01-11-2024 12:28 PM
I think I'm going to give it 10 days for the DLM to speed up. I have had similar issues in the past that fixed themselves and to be honest the engineer charges are a bit confusing so I'm going to leave it for now, I may message you in 10 days about this if that's okay.
on 01-11-2024 12:15 PM
You would not be charged if the fault is external etc.
Details of engineer charges can be viewed at :
https://community.talktalk.co.uk/t5/Articles/Engineer-charges/ta-p/2207291
on 01-11-2024 12:11 PM
Will I be charged for the engineer visit?
on 01-11-2024 11:43 AM
As the profile settings are correct, and speeds are lower than they should be, the next option is to progress towards an engineer.
Do you want to arrange this now ?
on 01-11-2024 08:26 AM
Now 200mbps with old modem.
on 01-11-2024 07:33 AM
Hi coinup,
OK thanks. Could you temporarily switch back to the old modem and check to see if the speeds come back up again
on 31-10-2024 04:02 PM
Turned them both off for 40min and no change, upload speed OK though.
on 31-10-2024 01:46 PM
Hi coinup,
Could you switch the modem and router off and leave them off for at least 30 minutes, then switch back on and check the speed again. Please let us know how you get on
on 31-10-2024 01:29 PM
I've had the new modem connected for an hour and a half.
