Router WiFi channel issue Sagem Fast 5364
HonestJim
Message 6 of 6
Can you please turn off the WiFi channel retuning function where user channel selection is overridden by the computer knows best function. As well as offering a selection of channel number 1-13 there is also an ‘Auto’ option if this sort of behaviour was wanted. So why on Earth did someone decided to implement this way is beyond me. It has the tendency to annoy the neighbours.
Thanks in advance
Jim
5 REPLIES 5
Message 1 of 6
No Problem 🙂
Message 2 of 6
Hi Karl,
Thanks for you help in this matter.
Jim
Message 3 of 6
Optimisation should now be turned off.
HonestJim
Message 4 of 6
Hi Karl,
I use a TP-Link Wireless N Nano Router Model No TL-WR702N in client mode to connect my YouView box and also my main PC to the Sagems WIFI. If the Sagem switches channel the link with the TP-Link  fails and the TP-Link doesn’t try to remake the connection. I either have to power cycle the TP-Link or log onto it and reboot it to resolve the issue.
regards
Jim
Message 5 of 6
Does the wifi channel optimisation have any effect on your equipment or connection ?
