Sagem router
Patd86
Message 13 of 13
Hi, I have been with TT fo over 3 years
No issues at all
No change to setup
About 3 months ago, broadband started dropping
Now its getting annoying
I've done the usual
Restarted
Checked cables
Moved router
Unplugged all devices and left 1
Changed filter
Moved router to master socket
This would only really help with internal though
My connection is dropping randomly though, so this hasn't really helped
It's not for long, but getting more frequent now
I've tried searching for my question but the replies I have found are not conclusive
I am prepared to buy my own replacement, but see a lot of people not being able to get them to work due to most requiring a username and password.
Help please
Old
12 REPLIES 12
Message 1 of 13
Hi @johnb201,
This topic was created by @Patd86, so the staff here will only be able to offer help to that customer in this topic, if you need help from the staff on this community then as @ferguson has mentioned you would need to start your own topic.
Message 2 of 13
@johnb201 Then start your own topic.
Message 3 of 13
I am not PATD86  im  JOHNB201
Message 4 of 13
Yes please it was fine with ordanary broadband
Message 5 of 13
Hi Patd86
I'm sorry for the delay. Would you like me to send a different router for testing?
Message 6 of 13
I'm by no means an expert, but I thi k it's mai ly my WiFi, I have most devices cabled now, their live test still tells me I have an issue
I am not paying anything for an engineer to visit.
I would however as I said, by my own non tt router if I knew I could configure it OK, I've ssen so many messages about other routers not working because they need a username and password, by tt don't give you 1
Old
GrannyB
Message 7 of 13
Me too. Sounds like you are living in my house, except I have been charged £40 for an engineer visit and it is just the same. Broadband dropped 4 times this week since 'chating' last Sunday when I was told to remove front plate from the main socket and plug a microfilter and the router cable into it that. Have now lost broadband 2 days running, white light never goes off but it is not a wifi issue as the computer is connected by cable to the router. Just can't wait for my contract to end!
johnb201
Message 8 of 13
had the same problem lasted 6 months and they kept saying the router was ok , in the end they sent me a different one and everything ok now.
Message 9 of 13
Sorry forgot to say, since letting TT do their check, I now cannot login to my router
Old
Message 10 of 13
Profile updated
I went through the TalkTalk help advice
Tried everything suggested
Results were
No faults on line to house
Speed check average 29 up, 2 down
Classified as an issue
I believe this mail ly WiFi issue
Old
Message 11 of 13
Hi Pat,
  • Name
  • Telephone number
  • Alternative contact number
Skynet_TX
Message 12 of 13
Hi @Patd86,
Do you know if the problem is with the router losing its connection to the internet (in which case a light on your router which is normally constantly lit will change colour or flash), or is it that you are losing Wi-Fi connection between your device(s) and your router (in which case the light(s) on the router will just carry on looking normal).
Do you have any ‘wired’ devices, do they also lose connection ?
The staff here won't be around now until Monday, but they should be able to respond to this post early next week to help.
