Setting Up TalkTalk FTTC with TP-LINK VR400
philonik
Message 10 of 10
I have joined TalkTalk Fibre 65 which connects using FTTC. I have bought a TP-Link VR400 Modem/Router to use instead of the provided TT one.
I cannot get the modem/router to give me an internet signal.
The master socket in the house is a OpenReach 5C Master Socker with a Ethernet Port on the left and a phone port on the right.
Please advise how I should connect the 2 up and wich wires to use. I have tried ethernet into one o the LAN ports in the back of the router and also a DSL cable into the DSL port with a filter on the master socket to convert from to DSL.
Nothing seems to work...
9 REPLIES 9
Message 1 of 10
Hi philonik
Can you add the home phone number rather than the mobile to your 'Community Profile' so we can locate your details and we can check on delivery of the TT router.
martswain
Message 2 of 10
The phone socket is just for that, the DSL signal is the other one, use that with the grey cable to the DSL input on the outer.
It is an RJ11 cable that is used, the first one, top left
https://accessories.talktalk.co.uk/?category=Accessories
Message 3 of 10
There are no rj11 ports on the master socket. Just an rj45 and a bt phone port (rectangle one)
Message 4 of 10
Thanks for updating your profile but could you also please add your TalkTalk landline telephone number so that we can locate you on our systems
Message 5 of 10
For Fibre 65 you just use an RJ11 cable from the master socket to the router.
The socket should be grey or white, DO NOT connect to the yellow LAN sockets.
As you have not received your TT router, have you actually been advised your service with TT has gone live ?
Message 6 of 10
Done
philonik
Message 7 of 10
I am not trying to connect 2 as I have not received my TT one yet.
I have read through this and these settings not match up with the TP link settings in their setup guide.
i was more curious as to how I should connect my master socket to my TP link router/modem
martswain
Message 8 of 10
@philonik you cannot connect 2 modem/routers to an incoming line.
Just follow the pictorial with the TT supplied router !
Connect the grey RJ11 to the appropriate socket on the master wall socket and that straight into the DSL socket on the back of the router, NO filters are required, that is done by the master socket faceplate.
Does the TT supplied device work on its own when connected to the incoming line ?
If you wish to use the VR400 as your main connection, then a setup guide for non TT devices is here
https://community.talktalk.co.uk/t5/Articles/Set-up-a-non-TalkTalk-router/ta-p/2205383
If you wish to connect the second device. it will need to be set up as an access point.
Please let us know exactly what you are trying to achieve.
Chris-TalkTalk
Message 9 of 10
Hi philonik,
  • Name
  • Telephone number
  • Alternative contact number
