on 07-12-2023 08:52 PM
Got a new box but now on catch up and netflix etc I have sound no picture. Everything else works fine. Is there something I haven't done when I plugged it all in?
on 08-12-2023 06:41 AM
Hi Denz4236,
If you can tell us the box model you have, we can help.
on 07-12-2023 11:07 PM
Which box do you have so we can offer tailored support.
General things to try are disconnecting the box from the mains and then restarting the box.
Checking cables, reversing the hdmi cable or using a different hdmi cable.
Check for updates.
As a last resort, a factory reset should reset all apps.
Hope this helps. Let us know how you get on.
