on 04-03-2025 09:11 PM
Please help....!
My download speed had consistently been around 40-41mbps for ages and it has now dropped to just 21mbps. Nothing with the equipment inside the house has changed for at least the last 12 months.
Stephen.
on 05-03-2025 11:02 AM
Hi Stephen,
Thanks for trying this. I've run a test on your line now which hasn't detected a fault. Is there any noise on the voice service?
on 05-03-2025 10:55 AM
Hello again Michelle,
The download speed seemed to have improved from the 21mbps I was getting yesterday, to approx. 33mbps when I ran a test before following your suggestion to switch off my router.
After leaving it unplugged for 30 mins and restarting, a speed test a few minutes ago, was still recording around 33mbps. Do you have any idea why (when nothing in the house has changed) it's dropped from a stable 40+ mbps until Monday when it was 21mbps and now to the current 33?
Stephen.
on 05-03-2025 09:03 AM
Thanks. Please let us know if there is no change in speeds.
on 05-03-2025 09:02 AM
Just followed your instructions and done that. Thanks!
on 05-03-2025 08:46 AM
Thanks for that!
on 05-03-2025 06:40 AM
I'm sorry to hear this. Could you try powering down the router for a full 30 minutes and then retest the speed again as this will reset the current session and can often increase the throughput speeds.
on 05-03-2025 06:08 AM
on 05-03-2025 12:05 AM
The talk talk test in 'My Connection' shows a speed of just 21mbps at present, when previously it was 41mbps. Is that what you mean Keith?
on 04-03-2025 09:56 PM
If you log into whichever router you have, what speed is reported there? This is often in the initial dashboard area.
