TalkTalk Sagemcom Hub - WiFi Issues
AldridgeAndy
Super Duper Contributor
Message 151 of 151
Hi TalkTalk,
Hopefully you can help...
In March 2024 I updated my iPhone XR to an iPhone 15, since then my new iPhone keeps intermittently reporting "no internet connection" despite a full WiFi signal. A reboot of the router or the handset resolves the issue until it occurs again. All other devices connected via Wi-Fi continue to function as normal.
This is at both my own and my mums house that have the same model Sagemcom WiFi Hub.
At both locations with the Sagemcom WiFi Hub my car (Volvo AAOS) will not connect to the WiFi despite a strong signal.
My brother also has TalkTalk Internet but with Amazon Eero, my car connects fine there, and my iPhone's WiFi functions as expected, no intermittent reporting of "no internet connection".
Aside from buying an OpenReach VDSL2 modem and a set of Amazon Eero, are there any other options available to me?
iPhone is on IOS 17.5.1 but this issue existed with previous iOS versions since brought in March 2024. I've also disabled "Private WiFi Address" within iOS at locations with the Sagemcom router in case it was upsetting things.
Volvo AAOS has recently had a big update from AAOS 11 to AAOS 12 and the issue persists.
Both Sagemcom Routers are on the latest version of Firmware.
Can you suggest a "next move" please?
Many thanks.
150 REPLIES 150
Message 121 of 151
HI Andy
Quick question, do you have Wi-Fi calling enabled?
AldridgeAndy
Message 122 of 151
Not yet, as the issue still persists with the TalkTalk Sagemcom router from iOS 17.4.1 right up to the recent iOS 17.6 and 17.6.1 releases.
Message 123 of 151
Hi @Deanosafc24
Please can you create your own topic on the Community, we can then take a look at this for you.
Deanosafc24
Whizz Kid
Message 124 of 151
Anymore information on this matter please?
DMHALL
Message 125 of 151
Hi Andy,
Apologies, no additional update as yet but the team are still investigating and testing this. We'll continue to chase for updates.
Message 126 of 151
Morning Andy
I'm really sorry for the delays.
I've chased the team again this morning for an update.
Message 127 of 151
Hi, I’m sure others will have relayed this information to you, iOS 17.6 has now been released and the issue with “no internet access” is still present on my iPhone 15 when connected to WiFi from the Sagemcom Router.
Message 128 of 151
Thanks @AldridgeAndy
I've passed this over to our Devices Team now and chased them for an update too.
AldridgeAndy
Message 129 of 151
Hi @Debbie-TalkTalk,
Just to add to this thread, as "belt and braces" I have raised this issue with Apple Support and they have ran diagnostics and basically said "no fault found". I have given the exact wording in the private message.
I have now "reset network settings" on my iPhone around three times in the past couple of months. The only two WiFi Networks now stored in my phone are my own home and my mums home. Both were added manually over the weekend.
Many thanks, Andy.
AldridgeAndy
Message 131 of 151
@Debbie-TalkTalk , sure I'll send across the serial numbers shortly.
Many thanks.
Message 132 of 151
@AldridgeAndy
Could you send me a Private Message with the serial numbers from both routers please? Our Devices Team want to take a look at this.
Message 133 of 151
No problem @Debbie-TalkTalk - I can now hang both 5364 & 5464 off the back of my network!
Message 134 of 151
Thanks @KeithFrench
I sure can. I will pass this over to our Devices Team now. Thanks for your help.
Message 135 of 151
There is no need for changes on the hubs Debbie. This may just be related to @AldridgeAndy's phone.
It affects two 5364s in different properties, but is OK with another relation with TalkTalk & has eeros.
Perhaps @Debbie-TalkTalk you could pass this to the Devices team to see if they can replicate the issue with a similar iPhone.
Message 136 of 151
Hi @AldridgeAndy
Is the issue still happening after these changes?
AldridgeAndy
Message 137 of 151
@Debbie-TalkTalk and @KeithFrench
Just to confirm that I've already tried the "reset network settings" and disabling "private WiFi address" as per the advice on the Apple Forums.
Many thanks to both of you for your help.
Message 138 of 151
Message 139 of 151
Hi @AldridgeAndy
Just for completeness & no surprise, neither the 5364 nor the 5464 support 160MHz channel bandwidth.
Message 140 of 151
Hi @AldridgeAndy
I have just checked & the 5364 does not support 160MHz bandwidth so I doubt if option 1 above is the problem.
