TalkTalk Sagemcom Hub - WiFi Issues
on 18-06-2024 01:11 PM
Message 132 of 132
Hi TalkTalk,
Hopefully you can help...
In March 2024 I updated my iPhone XR to an iPhone 15, since then my new iPhone keeps intermittently reporting "no internet connection" despite a full WiFi signal. A reboot of the router or the handset resolves the issue until it occurs again. All other devices connected via Wi-Fi continue to function as normal.
This is at both my own and my mums house that have the same model Sagemcom WiFi Hub.
At both locations with the Sagemcom WiFi Hub my car (Volvo AAOS) will not connect to the WiFi despite a strong signal.
My brother also has TalkTalk Internet but with Amazon Eero, my car connects fine there, and my iPhone's WiFi functions as expected, no intermittent reporting of "no internet connection".
Aside from buying an OpenReach VDSL2 modem and a set of Amazon Eero, are there any other options available to me?
iPhone is on IOS 17.5.1 but this issue existed with previous iOS versions since brought in March 2024. I've also disabled "Private WiFi Address" within iOS at locations with the Sagemcom router in case it was upsetting things.
Volvo AAOS has recently had a big update from AAOS 11 to AAOS 12 and the issue persists.
Both Sagemcom Routers are on the latest version of Firmware.
Can you suggest a "next move" please?
Many thanks.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
131 REPLIES 131
on 31-08-2024 05:54 PM
Message 81 of 132
Guys, I seem to remember now you mentioned this, that iPhones can be very fussy over channel bandwidth. However, that was from a long time ago.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 31-08-2024 05:32 PM
Message 82 of 132
2.4GHZ - 20MHZ
5GHZ - 80MHZ
DMHALL
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 31-08-2024 05:19 PM
Message 83 of 132
@Deanosafc24 Out of curiosity do you remember the static bandwidth settings for 2.4 and 5ghz?
I’m curious what your router was set too.
I’ve adjusted two routers so far with apparent success and I’ve got a third one to do tonight or tomorrow.
Will be interesting to see if optimisation undoes this possible fix, and also why the default setting from TalkTalk isn’t “auto”, is there a reason such as a firmware bug?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 31-08-2024 02:17 PM
Message 84 of 132
I’ve changed my bandwidth to Auto and it seems to be working upto now.
wonder if we’ve cracked the PROBLEM 🤞🤞🤞🤞🤞
DMHALL
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 30-08-2024 10:00 PM
Message 85 of 132
Yes, WiFi optimisation can change the channel bandwidth, but if it is correct now (20MHz for 2.4GHz and 80MHz for 5GHz) it does tend to leave it alone. The extender should follow the router's configuration, but there are times when if the router is set to 20MHz the 266 will use 40MHz. I reported this bug some while ago now, it does not affect the 5GHz, which is OK.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 30-08-2024 04:23 PM
Message 86 of 132
Hi @KeithFrench, my understanding is that it's not the actual broadcast channel, but the bandwidth allocated to the device(s) on that broadcast channel.
Does Wi-Fi optimisation adjust the "bandwidth" as well as the channel frequency? I was hoping it was just the broadcast channel frequency.
Any ideas if you can adjust the same on the Mesh extender?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 30-08-2024 04:18 PM
Message 87 of 132
Alas, @AldridgeAndy WiFi optimisation can & will override all channel allocations that you have just set. If only we could get it disabled.....
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 30-08-2024 04:15 PM
Message 88 of 132
Just a suggestion for anyone following this, I'll hopefully know more by Monday...
When checking the bandwidth available to the 2.4ghz and 5ghz channels on both routers I have access to they had different static values set, possibly from earlier investigations to this issue between the Sagemcom Router and iPhones.
I've changed the bandwidth setting to "Auto" for both 2.4ghz and 5ghz channels and also turned off WPS for both too.
This seems to have improved iPhone WiFi stability at my home address which also has the Fast 266 mesh repeater.
I carried out the same change at my mums address yesterday afternoon and when I return later today, I'll see if iPhone stability has improved there too.
After making the changes you need to restart your phone or leave the house and come back later and the new connection seems more stable on first impression. I not saying it's perfect, but it's improved.
One for the TalkTalk staff, having made the changes at my Mum's house my car can now connect to the Sagemcom there for the first time since I've took delivery. At my house I have the Fast 266 mesh repeater, does disabling WPS and applying "Auto channel bandwidth" on the router also copy through to the extender or does the extender have it's own settings that I can't access? It would be great if I could replicate the same settings to the extender so I can allow my car to connect to my own home's WiFi.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 22-08-2024 08:47 AM
Message 89 of 132
Hi Andy
I'll email the Team to see why they have not made contact with you.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 21-08-2024 07:01 PM
Message 90 of 132
Hope so, I may have to change to another ISP shortly
DMHALL
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 21-08-2024 06:59 PM
Message 91 of 132
@Deanosafc24 No it hasn’t and it’s becoming increasingly frustrating.
Let’s hope that Sagemcom or TalkTalk bring an agreeable solution to the table shortly.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 21-08-2024 06:47 PM
Message 92 of 132
This problem still has not been resolved 😡
DMHALL
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 15-08-2024 03:17 PM
Message 93 of 132
No Problem 🙂
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 15-08-2024 03:10 PM
Message 94 of 132
Many thanks Karl, will feed back as soon as I have anything to share.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 15-08-2024 03:08 PM
Message 95 of 132
OK, I've requested a Hub is sent.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 15-08-2024 03:04 PM
Message 96 of 132
Great, number should be in private notes already, it’s the 0121 number … I’ll go and double check and add if needed.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 15-08-2024 02:56 PM
Message 97 of 132
sorry, this was in response to your pm to Debbie... who is off today.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 15-08-2024 02:41 PM
Message 98 of 132
@Karl-TalkTalk Who was this message aimed at ?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 15-08-2024 02:14 PM
Message 99 of 132
We could try - can you add here phone number to the private notes section of your 'Community Profile'
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 14-08-2024 07:48 AM
Message 100 of 132
Hi Andy,
Thanks for confirming. I believe that the team are still investigating and trying different things to try and get to the bottom of this.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Related Content
- PC Running Slow - Wi-Fi Issue - Will Full Fibre Solve It? in Broadband
- AVOID TALKTALK: TalkTalk cancelling my transfer to a different broadband provider in Billing
- Error Trying to Book Engineering Appointment in Fibre
- Returning router (staff asked me to start a new thread) in Full Fibre
- Slow Upload Speed on FTTC Connection in Fibre
