TalkTalk Sagemcom Hub - WiFi Issues
AldridgeAndy
Super Duper Contributor
Message 145 of 145
Hi TalkTalk,
Hopefully you can help...
In March 2024 I updated my iPhone XR to an iPhone 15, since then my new iPhone keeps intermittently reporting "no internet connection" despite a full WiFi signal. A reboot of the router or the handset resolves the issue until it occurs again. All other devices connected via Wi-Fi continue to function as normal.
This is at both my own and my mums house that have the same model Sagemcom WiFi Hub.
At both locations with the Sagemcom WiFi Hub my car (Volvo AAOS) will not connect to the WiFi despite a strong signal.
My brother also has TalkTalk Internet but with Amazon Eero, my car connects fine there, and my iPhone's WiFi functions as expected, no intermittent reporting of "no internet connection".
Aside from buying an OpenReach VDSL2 modem and a set of Amazon Eero, are there any other options available to me?
iPhone is on IOS 17.5.1 but this issue existed with previous iOS versions since brought in March 2024. I've also disabled "Private WiFi Address" within iOS at locations with the Sagemcom router in case it was upsetting things.
Volvo AAOS has recently had a big update from AAOS 11 to AAOS 12 and the issue persists.
Both Sagemcom Routers are on the latest version of Firmware.
Can you suggest a "next move" please?
Many thanks.
144 REPLIES 144
AldridgeAndy
Message 61 of 145
When you next speak to the Faults Escalation Team ask them to send you a WiFi Hub2. I’m sure they will swap out without issue.
Message 62 of 145
FAST 5364
DMHALL
AldridgeAndy
Message 63 of 145
What model number is your new WiFi Hub?
WiFi Hub 2 is Model Number Fast 5464-1.T4
WiFi Hub was Model Number Fast 5364-3.T8
Message 64 of 145
I got a new Router off them but the problem is still there. Think I need a Hub 2. How would I know the difference?
DMHALL
AldridgeAndy
Message 65 of 145
The TalkTalk staff on this forum asked the “faults escalation team” to contact me.
The “faults escalation team” arranged for replacement WiFi Hub2 and then I returned the WiFi Hubs via my local post office.
Message 66 of 145
How did you get the WIFI Hub 2s mate?
DMHALL
AldridgeAndy
Message 67 of 145
@Deanosafc24 Since replacing the WiFi Hubs with WiFi Hub 2’s I’ve not experienced “no internet access” being reported on iPhones.
On Tuesday it will be a week since the routers were swapped out. If we can get to Tuesday without the problem reoccurring, I would think that there is a solution to the problem.
Message 68 of 145
How’s it going? The problem is still there for me.
DMHALL
AldridgeAndy
Message 69 of 145
I wanted to provide an update regarding my iPhone 15 and Sagemcom TalkTalk Wi-Fi Hub.
It's still early days, but since the Wi-Fi Hubs at my own home and my Mums home were swapped out for Wi-Fi Hub2 I've yet to experience a "No Internet Connection" message within iOS, or an App or Webpage struggle to load. Also, battery life on my iPhone 15 is massively improved. As I type at 14:30hrs on Thursday my handset is reporting 93% battery, usually I'd be at 70% by my lunchbreak at 13:00hrs.
Thank you to all involved, and hopefully this issue now has a resolution. I'll update this topic in a couple of days with feedback which will hopefully still be positive.
AldridgeAndy
Message 70 of 145
@KeithFrench My Fast 266 has been a decent bit of kit to date, it was just the big change in channel numbers that it just seemed to struggle to cope with. But now optimisation has done it's thing I don't normally get too many changes if any.
AldridgeAndy
Message 71 of 145
@KeithFrench I'm keeping my fingers crossed that my Fast 266 is just doing what they all do. If I can get my iPhone issue resolved, then I'll be in a good place. If not then I may be asking you nicely for tips on hanging some Eero's off one of the Lan ports on the Wi-Fi hub 🙂
I can't ask TalkTalk for any more kit at the moment it's been a bit of a challenge to get the 5464 to swap out and test.
Message 72 of 145
One thing though @AldridgeAndy, I have noticed that an F266 can take up to 5 minutes sometimes to connect from power on. I will address another issue with you by sending you a PM.
Message 73 of 145
Then perhaps @AldridgeAndy there is something wrong with your F266. Would you like me to ask @Debbie-TalkTalk to replace it for you?
AldridgeAndy
Message 74 of 145
Hi @KeithFrench after the "big channel change" from 132 to 36 the Fast 266 was showing Power and a flashing red light from memory.
When I took the Fast 266 into the same room as the router (it was only one bedroom away to start with) it still wouldn't reconnect on its own, it was only after I had powered up my laptop, logged in to the router and toggled the two switches to re-enable WPS that it sorted itself out.
I'll disable WPS again and see what happens. On my 5364 it was running with WPS disabled for months without issue. I am still convinced that despite disabling WPS at the router the extender presents to the outside world that WPS is enabled (my car checks for this, and as a security feature won't connect to networks with WPS enabled)
Message 75 of 145
Hi @AldridgeAndy
For the moment stay off getting your router's upgraded to V202. It is not a problem with the new firmware, but it is down to a minimum firmware combination mismatch of the 266 & router, once the router is running V202. I am currently trying to get more clarification from the TalkTalk Devices team on this.
To answer your question, once a 266 has been connected to a 5364/5464, then it will not need to use WPS anymore & so WPS can be safely disabled, which is what I do. Now the problem in your case would seem that you have lost communication between the 266 & router, rather than requiring a new WPS connection. When this happens what is the middle light showing on the F266, both when it is working & when it has failed:-
Green - Excellent signal strength
Amber - Good signal strength
Red (Flashing) - Lost connection with the router
The red & amber can easily be mistaken for each other IMHO.
AldridgeAndy
Message 76 of 145
Hi @KeithFrench  my 5364 and the new 5462 are both running firmware 174
I do have the original Wi-Fi extender with the three lights (which I went through the re-pairing process to link it to the new router)
I also have at my mums house a 5364 running 174 which will be swapped soon for a 5464.
You message is really timely, so a quick question for you. I re-paired the extender to the 5464 and all was good, and then disabled WPS on 5ghz and 2.4ghz. When Wi-Fi Optimisation moved the 5Ghz Channel from 132 (from memory) to the usual Channel 36 on the first night the extender became disconnected it couldn't see the Wi-Fi hub at all. Only when I re-enabled WPS on the two channels did it reconnect. Can we not turn off WPS any more if you have an extender paired and WiFi optimisation kicks in?
Message 77 of 145
Hi @AldridgeAndy
Nothing exactly to do with the current problem, but please can I just check, is your router is now on V202? I think that you also have the Sagemcom FAST266 WiFi Booster as well. Is your booster the older V1 model (three status lights on the front) or the newer V2, which only has one light on it?
AldridgeAndy
Message 78 of 145
@Deanosafc24  The two TalkTalk WiFi Hubs that I use daily, both seemed to improve with the bandwidth set to Auto and WPS disabled. But after a few days the one located at my mums house went back to its troublesome ways with frequent loss of connectivity for recent iPhones. The WiFi Hub at my house wasn’t as bad after the changes, there would be the odd drop but much less frequent.
Tonight I’ve swapped out the WiFi Hub at my house for a WiFi Hub2, it will be interesting to see if this resolves the issue with recent iPhones. I suspect there may be some different hardware inside as the web interface is much more snappy.
Once I can swap out the WiFi Hub at my mums house for a WiFi Hub2 this will be a great test as there are more devices coming and going there with family visiting all armed with iPhones. Hopefully that replacement Hub2 will arrive soon.
Once I have some feedback (hopefully positive) to share I’ll post an update.
If the Hub2 doesn’t solve the issue, then I may have to hang an Eero mesh off the LAN Ports of the WiFi hub, but the cost is going to smart despite a little bit of future proofing for when I go full fibre.
Message 79 of 145
How’s your connection been?
DMHALL
Message 80 of 145
Hi Andy
My colleague in our faults escalation team has advised that they will be contacting you again on Monday.
