TalkTalk Sagemcom Hub - WiFi Issues
AldridgeAndy
Super Duper Contributor
Message 132 of 132
Hi TalkTalk,
Hopefully you can help...
In March 2024 I updated my iPhone XR to an iPhone 15, since then my new iPhone keeps intermittently reporting "no internet connection" despite a full WiFi signal. A reboot of the router or the handset resolves the issue until it occurs again. All other devices connected via Wi-Fi continue to function as normal.
This is at both my own and my mums house that have the same model Sagemcom WiFi Hub.
At both locations with the Sagemcom WiFi Hub my car (Volvo AAOS) will not connect to the WiFi despite a strong signal.
My brother also has TalkTalk Internet but with Amazon Eero, my car connects fine there, and my iPhone's WiFi functions as expected, no intermittent reporting of "no internet connection".
Aside from buying an OpenReach VDSL2 modem and a set of Amazon Eero, are there any other options available to me?
iPhone is on IOS 17.5.1 but this issue existed with previous iOS versions since brought in March 2024. I've also disabled "Private WiFi Address" within iOS at locations with the Sagemcom router in case it was upsetting things.
Volvo AAOS has recently had a big update from AAOS 11 to AAOS 12 and the issue persists.
Both Sagemcom Routers are on the latest version of Firmware.
Can you suggest a "next move" please?
Many thanks.
131 REPLIES 131
Message 41 of 132
Hi @AldridgeAndy
Can I just confirm, you've not experienced any issues with the iPhone connections since connecting the WIFI hub2?
AldridgeAndy
Message 42 of 132
Excellent news, I hope that it’s a successful solution for you too.
Message 43 of 132
They are sending me a WiFi hub 2. 👍
DMHALL
AldridgeAndy
Message 44 of 132
@Deanosafc24  I can confirm that all is still working ok and “no internet access” seems to have been resolved.
Message 45 of 132
is your router n iPhone still working ok?
DMHALL
AldridgeAndy
Message 46 of 132
Visually identical with the exception than the Hub2 has a brighter “white light” and has a telephone socket for “digital voice” behind a sticker on the rear.
Message 47 of 132
Are they any different to look at?
DMHALL
AldridgeAndy
Message 48 of 132
When you next speak to the Faults Escalation Team ask them to send you a WiFi Hub2. I’m sure they will swap out without issue.
Message 49 of 132
FAST 5364
DMHALL
AldridgeAndy
Message 50 of 132
What model number is your new WiFi Hub?
WiFi Hub 2 is Model Number Fast 5464-1.T4
WiFi Hub was Model Number Fast 5364-3.T8
Message 51 of 132
I got a new Router off them but the problem is still there. Think I need a Hub 2. How would I know the difference?
DMHALL
AldridgeAndy
Message 52 of 132
The TalkTalk staff on this forum asked the “faults escalation team” to contact me.
The “faults escalation team” arranged for replacement WiFi Hub2 and then I returned the WiFi Hubs via my local post office.
Message 53 of 132
How did you get the WIFI Hub 2s mate?
DMHALL
AldridgeAndy
Message 54 of 132
@Deanosafc24 Since replacing the WiFi Hubs with WiFi Hub 2’s I’ve not experienced “no internet access” being reported on iPhones.
On Tuesday it will be a week since the routers were swapped out. If we can get to Tuesday without the problem reoccurring, I would think that there is a solution to the problem.
Message 55 of 132
How’s it going? The problem is still there for me.
DMHALL
AldridgeAndy
Message 56 of 132
I wanted to provide an update regarding my iPhone 15 and Sagemcom TalkTalk Wi-Fi Hub.
It's still early days, but since the Wi-Fi Hubs at my own home and my Mums home were swapped out for Wi-Fi Hub2 I've yet to experience a "No Internet Connection" message within iOS, or an App or Webpage struggle to load. Also, battery life on my iPhone 15 is massively improved. As I type at 14:30hrs on Thursday my handset is reporting 93% battery, usually I'd be at 70% by my lunchbreak at 13:00hrs.
Thank you to all involved, and hopefully this issue now has a resolution. I'll update this topic in a couple of days with feedback which will hopefully still be positive.
AldridgeAndy
Message 57 of 132
@KeithFrench My Fast 266 has been a decent bit of kit to date, it was just the big change in channel numbers that it just seemed to struggle to cope with. But now optimisation has done it's thing I don't normally get too many changes if any.
AldridgeAndy
Message 58 of 132
@KeithFrench I'm keeping my fingers crossed that my Fast 266 is just doing what they all do. If I can get my iPhone issue resolved, then I'll be in a good place. If not then I may be asking you nicely for tips on hanging some Eero's off one of the Lan ports on the Wi-Fi hub 🙂
I can't ask TalkTalk for any more kit at the moment it's been a bit of a challenge to get the 5464 to swap out and test.
Message 59 of 132
One thing though @AldridgeAndy, I have noticed that an F266 can take up to 5 minutes sometimes to connect from power on. I will address another issue with you by sending you a PM.
Message 60 of 132
Then perhaps @AldridgeAndy there is something wrong with your F266. Would you like me to ask @Debbie-TalkTalk to replace it for you?
Anonymous User
