WPS - Quick Query
wolfie138
Message 4 of 4
Hi all,
just got my Hub through the post today [yay!] and have been looking at the setup stuff. i'm a bit unsure about WPS as some of the wording is ambiguous: am i right in thinking i don't actually need to use it, and my TV/computers will just find the wifi signal as normal, and i just set up the logins for them as normal?
TIA
3 REPLIES 3
Message 1 of 4
magic, thanks 🙂
Message 2 of 4
Yes as above connect using the device wizards or manually. If you can turn off WPS on your router then do so as it's really not that secure to leave on anyway.
Fritz
Mr Bear 1
Whizz Kid
Message 3 of 4
I've got six WiFi devices here (two phones, a laptop, a tablet, a TV and a printer) and I don't even know where the WPS button is. Finding your SSID and typing in the passphrase should work every time.
