WiFi optimisation
Waster69
Message 9 of 9
Hi there. Sorry for starting a new thread on this topic if that is the wrong way to go but I am  newbie. I have read several posts in the community relating to problems caused by WiFi optimisation swapping WiFi channels. I am experiencing problems with my Sonos system and the advise from Sonos is to fix the WiFi channel, which I cannot do. Therefore can you please remove WiFi optimisation from my router so that I can pick and fix the channel. My router is a Sagemcom Fast 5364-3.
Hope you can help
Many thanks
Waster69
Waster69
8 REPLIES 8
Message 1 of 9
I'm really glad to hear this and thanks for confirming 🙂
Message 2 of 9
Hi Debbie. No issues with Sonos system since the change for nearly 2 weeks now so problem well and truly fixed
Many thanks
Waster69
Message 3 of 9
Hi Waster69
Is everything still working ok since your last post?
Message 4 of 9
Hi Waster69
That's great, I'm so glad to hear this 🙂
If you do experience any further issues then please let us know.
Waster69
Message 5 of 9
Hi Debbie. Many thanks for the swift action. No problems with my Sonos system so since the switch off and my Sonos. I will continue to monitor for the next few days and then post an update.
Waster69
Message 6 of 9
Hi Waster69
How's the connection been since the WIFI optimisation was switched off?
Message 7 of 9
Hi Waster69
The WIFI optimisation has now been switched off, please let us know how the connection compares.
Gliwmaeden2
Message 8 of 9
You did the right thing by starting your own thread, @Waster69.
Staff only reply to the original poster, as it helps avoid confusion.
They will respond after the weekend.
