cant connect raspberry pi
jay_ghai
Message 3 of 3
i bought a rasp pi 3 and im using an Ethernet cable to connect it too the internet but when i try to login in to it with Putty . it just says connection refused : network error  . can some one please help me out . i tried SSH ports on the octopi ip but it doesn't work  .
speedygonzalez
Whizz Kid
Message 1 of 3
You need to place an empty text file named ssh (note with no file extension) on the BOOT partition of your pi’s disk.
The file will enable the ssh server on startup.
Message 2 of 3
What are you trying to login to, the router or the pi??
