on 18-03-2024 09:55 AM
I need your help again, please.
I'd like to be able to check speeds on both lines registered to this account. While I can, usually, on my Windows 10 laptop, unfortunately I can't on my mobile. The message saying that the process sould take no longer than 2 minutes appears for a while, then I see "We've run into a problem". This happens on both numbers. Version 8.5.0 running in Chrome on Android 14.
Also, the guaranteed speeds are different, 43 Mbps at one address and 50 Mbps at the other. The addresses are in houses next to one another.
on 21-03-2024 10:45 AM
Thanks for your help Chris but I'm no closer to seeing the speed at the second number either at home or remotely, which stopped working in July '23.
If I could log onto the remote number's network, I could see the speed there but I don't know if that's possible.
I mentioned needing to see the second number's speed in post 21 on Monday.
on 21-03-2024 09:53 AM
OK thanks, so it allows you to record the speed test OK?
on 21-03-2024 08:59 AM
on 21-03-2024 08:54 AM
Thanks. What happens when you enter the telephone number?
on 21-03-2024 08:52 AM
on 21-03-2024 08:37 AM
Thanks. You should be able to attach a jpeg, are you using the camera icon?
on 21-03-2024 08:31 AM
Hi Chris. When using your link I get a "speedometer" reading of download speed, then upload speed. Then it finishes by asking for the landline number. I'd attach a screenshot but .jpg isn't an accepted format here.
on 21-03-2024 08:10 AM
Thanks. I can see from your earlier post that you've tried this link - Internet Speed Test (supportal-test.co.uk) - could you just let me know exactly what happens when you use the link
on 20-03-2024 06:21 PM
on 20-03-2024 02:02 PM
OK thanks for trying. What is the error message?
on 20-03-2024 01:13 PM
First test; got speed readings from second number on laptop and mobile; first number failed on laptop and mobile with error message.
Second test; first and second numbers fail on laptop and mobile with error message.
No incentive to do a third test ...
on 20-03-2024 08:48 AM
Hi hawaye,
Can you switch the router off and leave it off for at least 30 minutes, then switch back on and retest. Please let us know if this resolves the problem.
on 20-03-2024 08:04 AM
I use Edge on the laptop and Chrome on the phone. It happens on both. It has worked on Edge, several days ago, but it has never worked on Chrome. I can try other browsers on request.
on 20-03-2024 07:24 AM
Thanks Ferguson.
Your link goes to something that looks like the Ookla tester that TalkTalk used to use before the current tester version. But, unfortunately, it doesn't allow entry of a phone number for checking a second line remotely.
on 20-03-2024 07:10 AM
Apologies for the confusion. Does this also happen if you try a different browser? If this is still happening then we can ask our My Connection Team to take a look.
on 19-03-2024 11:22 PM
Sometimes it doesn't work via My Account. Try this, it's an alternative route to exactly the same tester:
on 19-03-2024 11:12 PM
Sorry Debbie, I can't have made it clear. Your speed tester doesn't work for me. Tonight, wired or wi-fi, laptop or mobile, first or second number, click on My Connection, Run a speed test, see the blue progress bar maybe 3/4 to the end and then I get the message, "We've run into a problem".
on 19-03-2024 12:07 PM
Hi hawaye
If you run a wired speed test using our speed tester what speed do you receive?
on 19-03-2024 12:04 PM
Thanks for the speed report yesterday Debbie. Yes, I believe I do need more help. This morning I'm getting the problem message on the mobile and the laptop on both numbers. I'd like to be able to check speeds without your kind assistance.
I use Fast.com when Talktalk doesn't work but I know from past experience the help chat people won't accept any other speed check than Talktalk's own.
on 19-03-2024 09:07 AM
Hi hawaye
Do you need any further help with this?
