speed
neilm831
Chat Champion
Message 6 of 6
Hi on my desktop pc i am only getting wifi speed 20 meg but via ethernet 71 meg.  Both 18 meg upload. I have checked my connections
5 REPLIES 5
Message 1 of 6
Thanks for the update 🙂
neilm831
Chat Champion
Message 2 of 6
Hi I got my speeds back up and running by changing frequency..now 71 meg too via wifi
Message 3 of 6
Slow speed, intermittent dropouts, breaks in the signal, no signal on some or all devices or no internet access might be caused by Wi-Fi interference from other local networks, which can also lead to a permanent reduction in speed. No ISP can be responsible for your local environment, this is mainly a byproduct of the popularity of Wi-Fi.
If you would like me to help you, please can you specify the make/model of TalkTalk router that you are using?
Message 4 of 6
Keith can really help troubleshoot wifi issues, but we also have a lot of help articles regarding wifi, such as Boosting your Wi-Fi performance - TalkTalk Help & Support
Try searching our help content fur useful tips.
Message 5 of 6
There are many things you can do to improve your wireless performance, although some of this will be subject to your PC as well as the router.
We are lucky to have an expert here who can advise on this, @KeithFrench could you help, please?
