splitting address ranges
ianclegg
Message 2 of 2
Is this possible ?
I have 2 wireless access points attached to my HG633 Router on my fibre broadband.
I would like to restrict which access point accesses which IP ranges that are allocated by DHCP
Thanks in anticipation
Ian Clegg
1 REPLY 1
Message 1 of 2
If I understand you correctly you have two different access points and each one has a different IP address range & you want the DHCP server on the HG635 to manage this?
No, that is not possible, as the router's DHCP server will only work with one IP address range.
