updated to fibre65
oldred
Message 16 of 16
Hi can you help please, upgraded to fibre65 and my wifi is now worse than before we have up to  10 devices connected at any one time but all constantly struggle to connect to the network and when watching players or streaming services prime/Netflix etc constant buffering I am being charged for this service and have been unable to use wifi consistently since upgrade please advise thanks?
15 REPLIES 15
Message 1 of 16
The team here won't be able to deal with this, you will need to contact customer services directly.
Message 2 of 16
Hi Ferguson thanks for the reply but the speed wasn't erratic it was nonexistent they had to supply a new router to bring the wifi into my property as the one I had was not fit for purpose this surely constitutes a loss of service if I am unable to use it.
Message 3 of 16
Raise a formal complaint, there is no other procedure for things like erratic wifi speeds, compensation is only generally awarded for total loss of service.
Message 4 of 16
Hi, Chris received my new router on 27/08/21 and have had great wifi all over the house ever since 10 plus devices connected with no problems. would like to discuss my bill from 19/07/21 to 18/08/21 and my next bill from 19/08/21 to 26/08/21 as I had no useable wifi at that time please review and advise, regards Paul.
Message 5 of 16
Hi oldred,
I've ordered a router, it should be with you within a couple of working days but please allow up to 5 working days for delivery
Message 6 of 16
@oldred I have merged your new topic into this existing thread, it will only cause confusion if you don't stick to this one.
Message 7 of 16
Hi, Chris sorry that you can't see my posts last spoke to Debbie on 05/08/21 and was offered a replacement router she to said that the line test was clear and that there had been no faults previously however I only have sporadic internet and most of the time it drops out cant stream any tv at all and my family is burning all of there mobile data to try n stay online please help.
Message 8 of 16
Hi oldred,
I'm sorry but we can't see any emails that you send, you need to post the Community
Line test is clear and your router is in sync at 74.8Mbps, also not showing any disconnections in the last 4 days - are you still unable to connect to the Internet?
Message 9 of 16
If I do not get a reply and the situation isn't resolved I will seek further advice
Message 10 of 16
Hi, Debbie have been trying to contact you but now have no wifi connection at all replied to you via my phone on 06/08/21 and then sent another mail with a plea for an update on the eta of the replacement router I am now using my mobile to tether my pc so I can send this. cannot view any Netflix, Prime or Now tv as they cant connect either have no signal to connect to or just keeps saying you have no wifi connection I have also been billed for my first month of wifi upgrade which seems a little bizarre as I am unable to use it
Message 11 of 16
Hi oldred
I've completed a line test which hasn't detected any faults and your line is in sync at 73.5mb.
Would you like me to send a replacement router for testing?
oldred
Message 12 of 16
powered down as advised and tried to stream programmes yesterday but was buffering quite regularly woke up this morning to no internet connection although the lights on my router and plugs are all green tried to search for my wifi address and was not on the list switched off and went to work switched back on tonight all connected again family at home all day with no internet connection paying for a service I'm not getting help, please.
Message 13 of 16
Hi oldred
How are you getting on following the 30 minute power down of the router?
oldred
Message 14 of 16
will try n get back to you thanks.
paulshent
Message 15 of 16
Have you tried a 30 min power down of router since upgrade.  If not please try this.
This should allow the router to create a new connection with network
Then retest
