on 23-10-2023 09:26 PM
Today i had my internet upgraded to full fibre, I have a Hub 2 but i won't be using it as i have a more advanced personal router and will keep the Hub 2 as backup.
The openreach engineer just told me to test internet which we did with Hub2 plugged in to avoid any possible issue, but he never checked if the phone worked. I was hoping to just use the Digital Voice App, but i can't see where to register mobiles etc - maybe as details not updated in my account. Also don't know if i can get a digital adapter tot use with my own router then i could use hand sets or do Talk Talk have list of VOIP phone they support.
On a side note - no fault of Talk Talk the open reach engineer has very muddy boots left mud all over laminate - luckily we'd put down protection on our carpet otherwise he'd have soiled 1100 pounds worth of flooring - i don't know if you can support but i'd like to raise as complaint most engineers. I've ever had either ask if ok to come in with boots or the have protectors they put over their boots.
on 08-12-2023 01:23 PM
Hi again,
They have advised that these changes would be done in your My Account and not in the app itself. I've included a help guide below, we've also been advised that it's set to a set time of 21 seconds.
About Call Divert - TalkTalk Help & Support
on 08-12-2023 11:42 AM
Ok thanks. I've fed this back to the team and will let you know as soon as they come back.
on 08-12-2023 11:25 AM
Hi Chris
Thanks for the update.
I’m seeking access, to alter the configuration to the default mobile number also to adjust call delay diverts times. None of these appear to be available via the Profile & Settings options on the App.
Benny.
on 08-12-2023 07:33 AM
Hi Benny,
I've received an update about this. The team who look after the digital voice app have said that that url isn't supposed to be accessible by the customer, the only features available are the ones in the app itself. They've asked if there's something specific that you are trying to do.
TalkTalk Digital Voice App - TalkTalk Help & Support
on 07-12-2023 03:49 PM
Hi Chris
Thanks for your help.
Benny.
on 07-12-2023 02:28 PM
I'll try to find out why this is happening. I'll let you know when I receive an update
on 06-12-2023 04:28 PM
Hi Chris
Thanks for persevering with this. And yes I have done as suggested on my Firefox, Edge and IOS platforms all with the same outcome.
'the requested URL was rejected. Please consult with your administrator'.
Unless this is an account specific issue, then I can’t be the only customer impacted by this glitch.
Benny.
on 06-12-2023 01:05 PM
And you've tried deleting browser history and cookies?
on 05-12-2023 04:07 PM
@Chris-TalkTalk wrote:OK thanks Benny, so it doesn't come up with a log in screen?
Thanks Chris
It generates the log in screen OK, however, when its populated with my details (Log in/Password) it generates this message;
'the requested URL was rejected. Please consult with your administrator.
Your support ID is: 16285912719907285538.'
on 05-12-2023 03:14 PM
on 05-12-2023 12:53 PM
Just to clarify my situation.
The A/C has been set up. The App has been loaded on my phone and is working.
The issue I’ve got is that I can’t get access to the A/C settings to alter my configuration e.g. add addition/amend mobile numbers or adjust call divert times. None of these are available via the Profile & Settings options on the App.
When I attempt to access the A/C via this link: https://voiceapp.allipvoice.uk/ I get these error messages; the requested URL was rejected. Please consult with your administrator.
Benny.
on 05-12-2023 08:47 AM
Hi Benny
Apologies for the delay, has anything changed since yesterday morning, is it still not working?
on 04-12-2023 10:13 AM
Hi Chris
Tried again today, still getting the same error.
Benny.
on 04-12-2023 08:41 AM
Hi Benny,
How are you getting on, has anything changed over the weekend?
on 01-12-2023 05:34 PM
Hi Chris
I’ve deleted the app from my phone, shut it down, rebooted, reinstalled the app and the issue remains.
The app works, however, when I try to login via the *link below to adjust my setting I get the same error code.
The requested URL was rejected. Please consult with your administrator. Your support ID is: 16285912719910890240
Benny.
on 01-12-2023 01:34 PM
Hi Benny
Could you try rebooting the device that's running the app and retest - please let us know how you get on
on 01-12-2023 10:47 AM
Thanks Michelle.
The initial setup and password creation worked fine. Ever since anytime I try to login via Firefox, Safari or edge I get the above error message.
Benny.
on 01-12-2023 10:29 AM
Thanks Michelle.
The initial setup and password creation worked fine it’s just since then any time I’ve tried to login, via Firefox, Safari or Edge, I get the same error message (see above) so I’m stuck.
Benny.
on 01-12-2023 06:47 AM
Sorry to hear this. Have you been able to amend settings prior to this or is this the first time you've tried? Is it still happening if you try again today?
on 30-11-2023 01:04 PM
Sorry to revisit this theme, however, I've tried to logon to amend some of my setting and I keep getting this message;
Your support ID is: 16285912719909261272
Any ideas?
I've tried Firefox and Edge browser's with the same outcome.
