on 14-06-2024 02:20 PM
Hello
I am on a 500Mbps package however I noticed in the last few months that my speed at the modem is automatically reduced to 94 every couple of week or so. I see this on the Eero app and when running a speed test the low speed is confirmed.
To remedy this I have to restart the Eero router or unplug the modem.
Considering that I pay for 500Mbps I wonder why this keeps happening, and what may be causing it and how to fix it once and for all.
TalkTalk can't certainly expect their customer to reboot their router every time the speed goes down, or can they?
Thank you for looking into this.
on 17-06-2024 01:24 PM
Thanks 🙂
on 17-06-2024 01:03 PM
Ok I'll try that next time.
on 17-06-2024 12:59 PM
You can connect a device such as a laptop directly to the ONT with an Ethernet cable bypassing the eero. I'm just suggesting that you could do this just long enough to run a couple speed tests
on 17-06-2024 12:55 PM
How can I do that? I thought you need the eero as gateway/router to connect all devices to?
on 17-06-2024 12:51 PM
Thanks. The next time it happens are you able to test with a device connected directly to the ONT, bypassing the eero, to see if the speed is still low at the ONT
on 17-06-2024 12:15 PM
Yes Chris. Restarting the eero seems to restore the speed.
on 17-06-2024 11:38 AM
OK thanks. So when the speed drops to 94Mbps, restarting the gateway eero restores the speed, without having to do anything at the ONT?
on 17-06-2024 10:34 AM
I've added my account number. Thanks
on 17-06-2024 10:29 AM
Thanks, could you add your TalkTalk home telephone number or account number to your community profile and I'll take a look at this for you
on 17-06-2024 10:00 AM
Hi Chris
Yes that's correct.
on 17-06-2024 09:43 AM
Hi davox,
Just to confirm, when you referred to the modem did you mean the ONT?
on 14-06-2024 02:58 PM
I don't have to power down the ONT but I have done a few times hoping in a permanent fix.
I have 3 Eeros.
on 14-06-2024 02:29 PM
Hi @davox
Do you have to power down the ONT on the wall also for the speed to increase?
How many eeros do you have?
on 14-06-2024 02:25 PM
Hi Debbie,
thanks for the quick reply.
Yes it has the latest updates.
on 14-06-2024 02:22 PM
Hi davox
Can I just check, does your eero have the latest software update? This can affect the speed. You can check the updates in the eero app.
