on 19-01-2024 09:44 PM
Full fibre installed in August and has been working fine with TalkTalk Wifi Hub 2. Upgraded package to Fibre 900, which activated yesterday.
EERO installation fails at WAN IP repeatedly, despite multiple resets of EERO and power cycles of CityFibre modem.
Tried Cat 5 & 6 ethernet cables, still fails to install. All 4 lights green on CityFibre modem.
Plugged Wifi Hub 2 back in and all works fine again (obviously not achieving the 900Mb.
Seems a very common fault looking at other community posts and that @Chris-TalkTalk may be the best at fixing it. Please can you help?
on 22-01-2024 01:06 PM
Hi Adam,
Apologies for the confusion, can I just confirm, do you currently have the eero or just the wifi hub 2?
on 22-01-2024 10:08 AM
Perfect, thanks for the help Michelle.
Just to confirm, should I expect a change of service/working EERO later today, or are we going back to the live date of 26th Jan and a change to My Account dates?
Thank you!
on 22-01-2024 10:01 AM
Hi Adam,
Thanks for the update. If there is no change by this afternoon then please let us know and we can escalate this for you.
on 22-01-2024 09:56 AM
Morning Chris,
Really appreciate you replying so swiftly, thank you. Interesting! Our original upgrade date was 26th Jan, however I received a text & email 17th Jan advising the Fibre 900 is now active and to use the EERO. My contract date on My Account also now shows 17th Jan start, changed from 26th Jan start.
Will wait to see what happens later today. If the service activates of 26th Jan, is there a way of getting the contract end date adjusted please? Thanks again.
on 22-01-2024 09:22 AM
Hi Adam,
It looks as though the upgrade hasn't gone through completely, still showing your old service on the City Fibre portal. I'll give it a couple of hours and then check again. If it's then still not gone through I'll ask our provisioing team to take a look
on 20-01-2024 03:55 PM
Oh interesting! I assumed the Hub 2 was maxed out or couldn't handle the speed. See what happens once the EERO 6 is finally up and running. Thanks for your input and help.
on 20-01-2024 03:51 PM
Hmm, that is not as good as I was hoping. I am on Fibre 150 with my Hub 2 I regularly get 152/152M. Perhaps the WiFi is not as good as it could be. Anyway, enough of that, as it is really a bit off-topic from what you asked. Hopefully, TalkTalk will pick this up on Monday for you.
on 20-01-2024 03:44 PM
I've only done a Wi-Fi speed test, which is 100-110Mb download with the Hub 2, with 100-110Mb upload.
Previous package was the Essential Fibre and achieved 70-75Mb download on Wi-Fi.
Frustrating that TalkTalk send an "easy" plug & play EERO Pro 6, with a 4-step setup, which then doesn't work...
on 20-01-2024 03:34 PM
Yes. Out of interest what sort of speed test results do you get on Fibre 900 with the hub 2?
on 20-01-2024 03:29 PM
Perfect, thank you. Will make sure my details are complete.
Am I okay to keep things running with my exisiting Wifi Hub 2? I don't want any background network checks to show no issues, just because I've got a working Hub 2 while the EERO isn't set up.
Thanks again.
on 20-01-2024 03:26 PM
Personally, I think the Hub 2 has better WiFi coverage, but I have asked one of TalkTalk's support to pick your thread up and investigate it for you.
To save yourself time, please make sure that your community profile includes your first & last names, Full Fibre account number & if you can, please include the serial number from your ONT in the Private Notes section. Please also try to include an alternative contact number. This can be done by clicking on your Avatar picture then click on "My Settings" followed by:-
on 20-01-2024 03:20 PM
Thank you. Just tried that, no change. Installation fails at WAN IP stage. As soon as I plug the Wifi Hub 2 back in, everything works fine again. Seems to be an issue with EERO connecting to the TalkTalk network.
on 19-01-2024 09:51 PM
Have you tried turning the ONT off for a minimum of 30 mins to clear all traces of the old speed?
