Eero Pro 6 can't reach the internet after installation
domo_jai
Message 11 of 11
I have got my Full Fibre installed today 21/8/2021, there are 3 green lights on power, PON and LAN. However, when I try to setup the eero, it said your eero pro6 can't reach the internet. I have tried the to set up the second eero as gateway and tried alternative LAN cable, but issue persist. I would like to know what's the root cause of the issue and need to get it fixed. Thank you.
10 REPLIES 10
Message 1 of 11
Hi domo_Jai,
It's currently been assigned to one of our Network team, we'll let you know when we receive any further updates or they may contact your directly
domo_jai
Message 2 of 11
Hi Karl,
Can I confirm if there is any update from network team please?
Message 3 of 11
One of our Network Teams has been assigned to this case and are now investigating.
domo_jai
Message 4 of 11
I think the situation is similar to this post, it could be my Openreach account/ profile has incomplete detail, hence no ip address received.
https://community.talktalk.co.uk/t5/Fibre/Fibre-not-working-since-installation/td-p/2967513
I have attached the ONT and eero photos:
domo_jai
Message 5 of 11
Hi Karl,
I have tried to reboot the ONT, three green lights are on but still can’t setup eero. I have also tried to connect my laptop to ONT port 1 directly, there is no internet connection.
Message 6 of 11
No Problem 🙂
I'll see what our network teams come back with.
domo_jai
Message 7 of 11
Hi Karl
Thank you for your reply.
I will try to reboot the ONT tonight after my work, I am not sure if there is any authentication/ configuration issue.
Message 8 of 11
Ok, just wanted to double check as a test was not detecting the ONT as on.
I've emailed our Network teams to take a look at this.
domo_jai
Message 9 of 11
Hi Karl,
As stated on the post, Green lights on power, PON and LAN respectively. The eero pro router is on solid blue. Cheers.
Message 10 of 11
Can you tell me what lights are on at the ONT,  The Box at the wall that you connect to.
