on 01-11-2024 10:45 PM
After replacing my eero 6 router with an eero pro six router I have noticed that my download speed has dropped by 25Mbps
on 06-11-2024 09:41 AM
Hi ricksmith,
How are you getting on, have your received another eero?
on 04-11-2024 03:26 PM
OK thanks. I'll check in a couple of days to see if another eero has been sent, if not then I'll order one
on 04-11-2024 12:21 PM
Received it Friday
on 04-11-2024 12:07 PM
Hi ricksmith,
When did you receive the first eero pro 6?
on 04-11-2024 07:26 AM
The speed has now settled down to around what I would expect for my full fibre 150 package. However the package I upgraded to was full fibre 900 including total home WiFi which I believe should include two eero pro six routers, I have only received 1 pro 6 router . Is it possible for you to look into the delivery of the second router. My upgrade go live date is 08/11.
on 04-11-2024 07:08 AM
Hi rick,
How are you getting on?
on 02-11-2024 10:51 AM
Is this the speed shown by the eero app or a speed test from a device?
