20-04-2025 02:56 PM - edited 20-04-2025 03:10 PM
One of my two eero 6s (mesh extender node) is faulty.
Devices connected to it are reporting a very low download speed test figure (about 20Mbps when it is normally 150Mbps). Signal strength is fine and there is no Wi-Fi interference. I have tried moving it to other locations within my property, but it is still the same.
If I turn this eero 6 off, leaving just the gateway eero in the mesh, the speed greatly improves. The same device, in the same location, but connected to the gateway eero, jumps up to about 120Mbps).
Please, can you send me a replacement eero?
on 24-04-2025 01:21 PM
No Problem 🙂
on 24-04-2025 01:20 PM
Thanks very much, Karl.
on 24-04-2025 12:43 PM
Hey @KeithFrench
The eero has now been ordered 🙂
on 23-04-2025 01:39 PM
You're Welcome 🙂
on 23-04-2025 01:37 PM
That's fine Karl, thanks for everything.
on 23-04-2025 01:35 PM
Hi Keith
Returns bag ordered - I'll have to order the eero tomorrow as the last order is still open and it will not let me place a second order until it completes
on 23-04-2025 01:19 PM
Thanks for that, however, my speed tests are still way down in the 60Mbps area, although the app reports the full fibre coming in at the ONT of 150Mbps. It all started after an eeroOS update & I now think it damaged the gateway as well as the extender. Please can you get me another eero 6 & a returns bag, so that I can send the faulty two back?
on 21-04-2025 03:14 PM
No Problem 🙂
on 21-04-2025 03:11 PM
Thanks very much @Karl-TalkTalk.
on 21-04-2025 02:18 PM
Hi Keith
I've ordered an eero for you.
on 20-04-2025 04:45 PM
Hi @KeithFrench your post has been escalated.👍
