Faulty eero 6
Message 12 of 12
One of my two eero 6s (mesh extender node) is faulty.
Devices connected to it are reporting a very low download speed test figure (about 20Mbps when it is normally 150Mbps). Signal strength is fine and there is no Wi-Fi interference. I have tried moving it to other locations within my property, but it is still the same.
If I turn this eero 6 off, leaving just the gateway eero in the mesh, the speed greatly improves. The same device, in the same location, but connected to the gateway eero, jumps up to about 120Mbps).
Please, can you send me a replacement eero?
11 REPLIES 11
Message 1 of 12
No Problem 🙂
Message 2 of 12
Thanks very much, Karl.
Message 3 of 12
Hey @KeithFrench
The eero has now been ordered 🙂
Message 4 of 12
You're Welcome 🙂
Message 5 of 12
That's fine Karl, thanks for everything.
Message 6 of 12
Hi Keith
Returns bag ordered - I'll have to order the eero tomorrow as the last order is still open and it will not let me place a second order until it completes
Message 7 of 12
Hi @Karl-TalkTalk
Thanks for that, however, my speed tests are still way down in the 60Mbps area, although the app reports the full fibre coming in at the ONT of 150Mbps. It all started after an eeroOS update & I now think it damaged the gateway as well as the extender. Please can you get me another eero 6 & a returns bag, so that I can send the faulty two back?
Message 8 of 12
 No Problem 🙂
Message 9 of 12
Thanks very much @Karl-TalkTalk
Message 10 of 12
Hi Keith
I've ordered an eero for you.
Divsec
Message 11 of 12
Hi @KeithFrench your post has been escalated.👍
From the 29th of March our TalkTalk Community will move to peer-to-peer support and the TalkTalk team will no longer be here to support with queries. Don't worry we still have plenty of ways to reach out if you need to speak to TalkTalk directly. For more details check out the link here: How to contact TalkTalk Broadband - Help & Support. 03451720088
